AE not displaying cylinder #4 & #7
When looking at the live data on Auto Enginuity, why would it not give me the option to see missfire information for cylinder #4 and cylinder#7 ? Should it not list all 8 cylinders?
Not sure, still learning AE myself. Subscribing
Just started playing with my AE as well, subscribing
What is this misfire reading you are referring to? Who cares? We don't have spark plugs or coil on plug. Can you elaborate? There are parameters on the AE we need not concern ourselves with on the 7.3. There are a bunch of them if you look.
Originally Posted by Tenn01PSD350
(Post 7948302)
Look where? The manual that came with my version of AE Ford Enhanced is crap and no where have I found an "AE 7.3 Bible", that you seem to be refering too, that explains all the parameters. Regardless of whether the parameters apply or not it should list the parameters for all 8 cylinders and not just six of them, unless there is a specific reason it would not. Which goes back to my original question. The parameters are listed in the the drop down boxes under the live data tab. |
You also need a shop manual. Don't log things that have no bearing on our trucks. If you want a pissing contest, look elsewhere. I will not participate. Good luck to you.
Quote:
Originally Posted by DAI532 View Post I am located in Gainesville,GA. 50 Miles NE of Atlanta. You are pretty close to these guys: http://powerstrokehelp.com/ The are located in Buford down the street from ya. Maybe related to that other weird thread????????? __________________ 2000 7.3 powerstroke. Bull dog tuner. Air raid cold air intake. AIH delete. Oil crossover. |
Mike you are giving up way to easy, are you OK:-X01. I thought you would want him to at least check the plug wires:-missingt
But DIA I do know what you mean I could not get a reading I felt good about this week checking my rotational velocity on the AE it read 0.0 on all 8 cylinders. I still have not got to the bottom of this.:-banghead |
(Post 7948435)
Originally Posted by Bigcat350
(Post 7948473)
... checking my rotational velocity on the AE it read 0.0 on all 8 cylinders. I still have not got to the bottom of this.:-banghead
I have no answer on the misfire thing since that is geared toward the spark plug crowd. I've never even tried to look at that on my AE since it's not applicable anyway. Rotational velocity is the thing you want to look at on the live data tab, along with other things that seem to make sense. Best way to learn is just play around with it. |
Originally Posted by F350-6
(Post 7948613)
0.0 is good, but unusual on all 8 cylinders. EOT needs to be up around 160 or 170 deg, rpm's need to be at idle, and accessories like the AC need to be in the OFF position.
I have no answer on the misfire thing since that is geared toward the spark plug crowd. I've never even tried to look at that on my AE since it's not applicable anyway. Rotational velocity is the thing you want to look at on the live data tab, along with other things that seem to make sense. Best way to learn is just play around with it. Thanks. I think you understand I was asking a question about software and not my actual engine. I've tried your previous suggestions, and appreciate your continued efforts to help. As you can tell I am still searching for a solution. What would you consider out of the norm on the rotational velocity? And, what would that tell you about an intermittent miss at different RPM's? (If the two are related.) As I stated in my other post, the buzz test, KOEO, KEOR, and CCT's all passed. UVCH's are all good, everything ohm's out, fuel pressure is good, fresh oil, about to give up and set it on fire . . . |
For rotational velocity, typically readings over 5 are considered bad. For an intermittent miss at different RPM's, two things come to mind. 1) Intermittent is tough to track down, and even harder to do over the internet. 2) Diesel engines make funny noises and run a lot different than gas motors. Sometimes I wonder if they make a noise every once in a while just to see if you're paying attention.
I understand you're asking about the software, and I understand there's no good 7.3 AE bible. If you've got some time on your hands, feel free to write us the 7.3 AE manual once you get this stuff figured out. I'm computer challenged and understand just enough to get by. |
Would one of you guys with an AE be able to run the test he's looking at and see if you get all 8 cyl's or just 6? I'm curious too cause things like this bug me.
Originally Posted by twags6
(Post 7950975)
Guess what? No such parameters even appear on my pull downs for logging. Of course it does not change what I said and maybe the OP saw them elsewhere. Nonetheless, it is a parameter of no use to our diesels. If the OP tells me where it is I will look. More interesting is how I logged zeros on all cylinder velocity readings like Eddie did. Of course I only did this to about 95*EOT so that may be why. It is getting dark out and I always run vel tests on a hot engine. Makes me think about how Eddie gets zeros on his when it is hot. So Eddie, the next time you do it hot, get an EOT reading too just to compare. Just trying to figure it out. To the OP, I was not trying to bust your chops. I was trying to keep you away from things that have no bearing on our trucks. The only manual a lot of us have for these things is between our ears and what we have picked up so I apologize if I was condescending. I agree the AE manual sucks and is lacking.:-wink Good luck with your truck. Don't let me run you off as I am pretty helpful usually unless something rubs me the wrong way. |
Mike I did my test with the EOT at 100 also 160, 170,180 and 190 I think the day I called you I was at 180 when I left the message. I have now idea how its staying at 0.0
