highest GVW for 86 f350 long wheel base
Hi i'm looking at buying a 86 f350 ramp truck with LONG wheel base 5spd 6.9 Sellers telling me (door tags coviently missing) that the GVW is 13500.I didn't think a 86 f350's EVER came with a GVW higher than 10K.Could someone here set me straight THANKS
get the vin, go to the ford fleet vin decoder, it will tell you what the factory said it could do
https://www.fleet.ford.com/maintenan...ls/default.asp |
My 85 F-350 RollBack DULLY unladen weight is 7,380. I have it registered at 17,000 gross weight (class 6).
Heaviest thing I've piggy backed was no more then 6,500. 7,380 + 6,500 = 13,880 Add full gas tanks, and people I've been over 14,000 a few times with no problems, that and the fact I can tow one on the towbar is why im registered at 17,000. In my state atleast I can pick whatever gross weight class 10,000 13,500 or 17,000+ (as long as I dont get caught over the limit im ok) As for what the truck can handle is another story. Ford vin decoder says this about my truck GVWR Class: Class H GVWR Range: 9,001 - 10,000 Pounds I honestly dont have a clue what the deal is. |
Originally Posted by Swatter
(Post 7855487)
aluminum 17 1/2 foot Jerr-Dan
Sorry, not much help here. My '81 book shows a max GVWR of 9100 for an F350. Here in California the vehicle title matches the GVWR in the doorsill. I think in other states you can title the GVWR a lot higher. You just pay higher registration fees.
FWIW, I would also be concerned about finding out the axle ratio. |
A SRW GVW is 9100. A DRW is 10200. A cab-n-chassis is 11400
OK folks THANKS for all the input + help
