buy a manual. ;-)
yeah... I have 2 of them... But when you brother buys a truck and wants to barrow the books, ya never see them again lol
Number 2 - Vacuum canister
Number 3 - MAP sensor (could also be the BP sensor, hard to tell) Number 7 - Idle Air Control (IAC) / Idle Air Bypass (IAB) IAC is the more popular name Number 10 - Is it on the fuel rail? If so, it's the fuel pressure regulator (FPR) |
# 4 is the cruise control diaphram/motor.
# 8 I believe the coil is under this cover. # 9 Is a vaccume check valve. |
1. air filter for smog pump
2. vacuum reservoir 3. map sensor 4. cruise control vacuum servo 5. fuel pump relay/eec relay bracket 6. same as 5 7. idle air control solenoid 8. ignition coil, tad, tab solenoids and evr solenoid are under the cover 9. thermostatic vacuum switch or check valve for heat riser 10. fuel pressure regulator |
Haha sweet, I got mine right. :D
