About to change my HPOP Seal any steps for me?
Title says it, Ive had the fuel bowl off before so I can get that far. Anything else I should know or is there a writeup?
What seal, where did you get it from, and hold on, I will give you a link
http://www.dieselorings.com/index.ph...&cat=8&group=6
There is a PDF file on this page that should help you. Good Luck, and enjoy!! |
Originally Posted by just another truck
(Post 7849087)
There is a PDF file on this page that should help you. Good Luck, and enjoy!! I am going to attack this soon too as my engine valley is shiny and wet. I don't know which seal(s) are leaking yet, but I'm going use them all and be done with it (except the "non-serviceabe" plug...if it's not leaking, then I'm leaving it alone). Is there any good information, good ideas or best practices anybody has to share to help this go as smoothly as possible? Any advice is appreciated. Sorry for the partial :-hijacked, but I couldn't just put "subscribing" in my post...:-X10 |
I got the kit from Ford it came with 3 orings, does that include the service plug or the rear plug o ring?
Sorry, cant help you there, I had got my Gasket from the IH dealer down the street, then went to Guzzle ( Bob) when I was still leaking.
(Post 7849738)
Originally Posted by Yougotthehit
(Post 7849540)
Originally Posted by brian42
(Post 7849929)
Is the gasket (is that the one with the strainer?) worth changing while I have it off? Or should I leave well enough alone if it's not leaking and hope for the best? :confused:
The important thing in replacing the o-rings is to allow the loc-tite to cure for a minimum of two hours before re-starting the engine. Loc-tite specs out 24 hour cure time for their sealing compound but I have had success with only 2 hours. If you have drained your HPOP, it will take some time to refill the reservoir with only the LPOP so make sure that your reservoir is manually filled from 3/4 to 1" from the top. After it fires off, it may take 50 miles or so to get the air worked out of the oil rails before the engine settles down. |
Thanks for all the info Bob.
Do you recommend any other seals I should replace (besides your 7 o-ring HPOP kit) while I've got the HPOP out? |
(Post 7849999)
Originally Posted by guzzle92
(Post 7850010)
Is there a particular reason that you are pulling the HPOP besides just replacing the o-rings? If not, I would do it on the truck.
When you remove the bolts and the HPOP from the engine front cover, discard that gasket and replace it with a new one.
(Post 7850490)
I have not this work before, but is it possible to spray a large amount of carb cleaner or brake cleaner to remove enough oil and find out were the oil is leaking?
Nick |
Finding this leak is a pain, I had cleaned everything and stuffed white rags under teh HPOP until I cound find the exact spot ( and already replaced everything else I could)
