Wrench party in Sept?
Would anyone be up for a wrench party sometime in Sept? Since I am getting Mater registered soon I want to get my tranny rebuilt. I was figuring we could have it at my place unless Dave Sr. is willing to let me borrow his shop if it is empty. I am not seeting anything right now cause I still have to get the body mounts finished and weld in new floors. I was thinking more towards the end of the month, unless I finish everything else sooner.
I'm game, Are we going to be dropping the tranny, rebuilding it and putting it back in?
Yes, that is the game plan. I have the rebuild kit sitting on my work bench and I have a few references we can go off of.
Just let me know when your ready and I will check with dad .It will be alot easier to do in the shop.
Sounds good to me...as long as it's not Labor day weekend the 6th and 7th.
Ha, make it for after I get back and I will be there!
It will most likely be the last weekend in Sept, so you will be here! Besides if I don't have the truck finished by then we will have to pull the tranny out and toss it in the back of your truck to get it to Dave Sr.'s shop.
Sounds like fun.
jimbo out |
What do you have torn apart that you couldn't drive it over to the shop ?
Originally Posted by mudder460
(Post 7885360)
Right now I have the drivers floorboard cut out and I am getting ready to cut out the passenger side. I also only have half the cab bolted to the frame. I am working on getting a new body bushing set, I found one that has all the pieces I need. After I get those done I will have no problem driving it.
OK I am working on the body bushings now. I am almost finished....would be done but I keep running into snags! Right now I am looking for grade 8 washers that are 1/2" inside diameter and 2" outside.
How does Sat the 26th sound for the tranny rebuild to everyone? |
Alright, I finally got everything I need to finish the bushings and be done with it all! The simplest job seems to take the hardest to find parts but can be resolved with a simple solution! Tomorrow the bushings will be done if it isn't raining when I get up, then it will be just to finish the floor pans! I did get a tag for Mater today so he is street legal now!
What's the scoop Andy ???
I got the body bolted to the frame again "CHEERING" and I have a friend that is going to bring a good welder over on wed to weld in the floor pan. I will finish up the other side after we finish the tranny. So if everyone is game we could do the tranny this Sat.
