Ford Truck Enthusiasts Forums
-   Pre-Power Stroke Diesel (7.3L IDI & 6.9L) (https://www.ford-trucks.com/forums/forum117/)
-   -   Allison at545 6.9 diesel (https://www.ford-trucks.com/forums/876565-allison-at545-6-9-diesel.html)
joe f350 08-21-2009 01:06 AM
u nrrd 9-10 psi to run the truck
562dragnhra 08-21-2009 01:16 AM
are you sure??? cuz kragen has the same Facet Posi flow that its rated from 4 to 7 psi and 32 GPH, would that work???
LCAM-01XA 08-21-2009 01:44 AM
That one will work good. The 9-10 psi Joe is talking about is too much, right there at the borderline of throwing your timing off actually.
562dragnhra 08-21-2009 01:54 AM
Sweet thanks!!! but will it work with the banks sidewinder turbo i have on my 6.9 diesel????
Skip1970 08-21-2009 02:04 AM
wheres all the pictures?
562dragnhra 08-21-2009 02:15 AM
itson the right side under albums
Mat J 08-21-2009 06:12 PM
yeah it will work with the turbo hook up a pressure gauge at the fuel filter and see how much psi you acutally get there I think the stock lift pump is 7 if I remember reading correctly.
