1989 Ford F250 V8 No fuel Will Not Start!
Hello All,
I am a new member and I really could use some advice. I really love my truck and need to get back it go to work.:confused: 1989 Ford F250 V8 Four Wheel Drive Automatic 1989 Ford F250 460 engine with fuel injection not getting fuel. Replaced inline fuel pump, Replaced fuel filter, fuel tank switch on dash, replaced fuel selector switch in cab drivers side by park brake, Replaced Dual function Reservoir just before fuel pump, Replaced fuel pump relay under hood driver side. Not getting any fuel in line. Can Both in tank fuel pumps be bad at same time ? Can hear in tank pumps hum when selected. Both tanks are full of fuel? When I spray starter fluid in throttle body truck will start but dies as soon as spray is gone. have fuel to rear end side of reservoir but nothing coming out front of reservoir I have a new reservoir installed. Any Idea's are Welcome! Thank You Leroy<o:p></o:p> |
Welcome to FTE Leroy. If you post this in the tech forum you should receive a quick reply.
