F series Front end
ok i have a 96 F-250 2wd and i have another truck same year but its a F-150 2wd witch has the frame bent. i ve looked under both of them and besides the spindles being different everything looks the same. so what i am trying to do is my friend has a 95 F-150 4x4 that the body is falling off of and wants to give me so if i were to take everything off his 150 like front susp, rear susp tranny and transfercase and drive shafts i could turn my F-250 into 4x4.
yes you can it is a straight bolt on swap and you only need the rearend if its different lug pattern or or gear ratio.
ok thanx a lot, so if i where going to lift the truck after i get everything in i would get a lift kit for a F-150 right?
IIRC the TTB bolt pattern for the F150 and F250(where they bolt to the crossmember) are different.
what does IIRC stand for
IIRC = If I Remember Correctly
FWIW = For What Its Worth I try to be younger than i am:D |
lol ok. now i know
Originally Posted by Diesel_Brad
(Post 7749978)
Not that i know of. maybe the younger crowd could do a list8D
(Post 7751372)
Roger http://www.gaarde.org/Acronyms/ |
