Pre-Bent Stainless Steel Brake Lines
With the rusted/busted rear brake line posts here & in the Excusion threads, I contacted some tubing manufacturers to see if they offer Stainless Steel Versions.
Classic Tube (www.ClassicTube.Com) said they have patterns for "1999 F350 4x4 Regular Cab-Long bed & Extended Cab-LongBed" and "2001 F250 4x4 Extended Cab – Shortbed". Can anyone with access to a Ford catalog, see if a Crew Cab Short Bed uses the same lines as either one of these? Also, is an OE line available from Ford? P/N? Mine is rusty & I'd like to replace it before it bust's. |
Have you considered just buying the tubing, a bending tool & flaring tool and just making them yourself? Shouldn't be too hard to do.
