Ford Truck Enthusiasts Forums
-   6.0L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum107/)
-   -   2003 ford f250 6.0L turbo diesel problems help (https://www.ford-trucks.com/forums/866597-2003-ford-f250-6-0l-turbo-diesel-problems-help.html)
caleb1563 07-10-2009 02:16 PM
i have a 03 f250 and when its cold it barley starts and its not driveable until it is warm it was never like this before and on top of that the turbo is not working at all
any ideas at all thanks
GRAY MULE 07-11-2009 12:05 AM
i have the same truck as you,and had the exact same problem with mine,so i took it to my dealer and first of all i needed my computer reflashed and updated with a cold start update,and secondly i had 2 injectors down also. i let the dealership fix it and sadly it cost me 1200 bucks parts and labor, but happily it runs like a brand new one now.
Maxium4x4 07-12-2009 01:18 PM
Welcome to FTE caleb1563 :-X22 I moved you from General Diesel to year specific for your engine. Can you give us information on the truck, original owner ect?
bigdad 10-18-2011 09:54 PM
i have an 2003 f350 with a 6.0 and it wont start. i replaced the high pressure oil pump.still no start,,please helpme
bismic 10-18-2011 10:04 PM
Look in the Tech Folder - there is a no-start troubleshooting thread.
We also need specifics:
Any mods?
codes?
Any recent issues w/ alternator or batteries?
How long did you crank after the HPOP replacement?
What oil and oil filters are you using?
BLADE35 10-18-2011 10:31 PM
Gauges would also be a big help here to check things out like your FICM
Alot of us on here run a Scan Gauge or Edge Insight I beleive
I use the SG great unit for 160.00 check it out
www.scangauge.com
But some things can be checked with a DVM=digital volt meter if in a pinch
Here is the trouble shoot checklist Bismic suggesteed
https://www.ford-trucks.com/forums/8...condition.html
eode6s 06-13-2013 07:06 PM
2005 6.0, no power!! No acceleration, cannot even get out of her own way. Had her in reverse, had to look to see if she was in neutral; as there was no movement what-so-ever. Visit to Dealer; all 8 fuel injectors, 8 glow plugs, and Y pipe changed. $4300 and dealer says there is nothing wrong with her. New EGR, air, oil and fuel filters. Running Royal Purple 15w40 syn. Only mods are volant cold air intake and after market exhaust. I am at a loss.
bismic 06-13-2013 08:40 PM
see post #5
cheezit 06-13-2013 10:07 PM
really reopening a 5yr thread?
listen to mark, post your results in a new thread
© 2018 MH Sub I, LLC dba Internet Brands
