Interior Trim
Guys,
Just bought a 93L as a rolling chassis and I am in need of a couple of interior trim pieces. What model F150/Bronco came with the same charcoal colored interior? Also, in need of the plastic rear tube bumber step. Scott |
93 Lightning? I thought the dash and trim was all a unique color to the lightning, with gray, red, tan and blue being available in the standard trucks.
Hope down to the 87-96 section, several people have done lightning conversions and know much more about them than I do. |
Virto,
I am missing some pieces and thought someone here would know of another model that would interchange with the one year only 93L interior. |
If its the darker gray then 92-93 should be the same gray regardless of F150 F250 F350 Bronco etc. From 94-96 it was a lighter gray.
Originally Posted by polljimmy
(Post 7712091)
Installing trim is one of the most rewarding home improvement projects you can do. No matter what style you choose, you’ll take pride in the finished product . . . as long as you get all those joints tight.
Originally Posted by TexasGuy001
(Post 7705441)
I belive 94-96 = medium opal gray what parts specifically are you looking for? We might have better advice on where to find em. |
[quote=Virto;7703966]93 Lightning? I thought the dash and trim was all a unique color to the lightning, with gray, red, tan and blue being available in the standard trucks.
only the seats, perferated leather steering wheel, the orange pointers on cluster w red line on tach in red paint. and possible 93 door panels cause I havent seen the felt insert that 93 L door panels had on anything else yet. other than that its all normal upper level xlt stuff |
my94lightning,
I am in need of a glove box door, drivers door panel (my felt trim is in really good shape), and molding over the drivers side door window. Scott |
well, since what you describe are (cheaper parts ish)except door panel, I would have a buddy at a dealer run a locate, and see if anywhere shows them available.
1 glove box 2 drivers A pillar trim 3 drivers door panel #1 should be easy find, and not to expensive. #2 Are you talking about the trim that goes up from the dash and then to the rear of roof, and it holds up the headliner?, if so its called a A pillar trim, if not, is molding atached to cab or door? #3 door trim panel is expensive if it is available still, you say your felt is good, what is wrong with your door panel? also I believe the felt inserts do not come off the door panel, I think they are plastic welded from behind. |
my94,
Sorry it took so long to respond, I was camping in Tennessee. There is a truck boneyard near me so I will try there and see what I can come up with. If that turns up nothing then I will try some alternative sources. |
i'll help you, visit my site send me what you are looking for and give me a vin so I get it right. I'll see if there are any parts avail or at another dealer.
Ed |
