zf s5 42 running 250 degrees
Anybody know what will make a tranny run hot like this? I swapped the short range gear set for a wide range one and it shifts nice but it is running too hot. I tried atf and gear oil and it looks like I have to pull the tranny again. I didnt put new bearings in the main or counter shaft but all my lashs between gears is .006 so I wouldn't think that would be a problem.
You probably have the preload on the bearings to tight.
The ZF is to have light oil only, technically ATF! -Enjoy fh <font color="#FF0000">:</font> )_~ |
Turned out to be an exhaust clamp touching the transmission. It was just cooking the poor thing.
