Do You Have An Airbag Light On In Your Truck ?
http://thumbs300.1aauto.com/STC/1ASTC00043A.jpghttp://thumbs300.1aauto.com/STC/1ASTC00043.jpg
Then chances are that your clock spring may be worn. This part is designed to replace the factory clock spring with no modification. We have the part at a fraction of the cost from a mechanic or the dealer. The clock spring in your car is a very important part of your vehicle's airbag system. It sits behind the air bag and allows the mounting of steering wheel mounted accessories such as cruise control and audio controls. It also provides power to the airbag so it can deploy during a crash. The electrical connections to the steering wheel and the airbag have to be in the form of a spring because the steering wheel turns and the electrical connection must be maintained no matter the angle of the steering wheel. Over time and many turns the clock spring wears out and may cause failure of electrical components on the steering wheel or worse, failure of the airbag to deploy. If your airbag light is on or your steering wheel mounted controls aren't working anymore, replace your clock spring with the right part the first time. You will save money in the long run Click on the link below to purchase through our secure website. 1999-2004 FORD F150 & F250 CLOCK SPRING 1994 FORD F150 & F250 & FULL SIZE BRONCO CLOCK SPRING 2000-2001 FORD EXCURSION CLOCK SPRING 1999-2002 FORD EXPEDITION CLOCK SPRING 1A Auto Parts Offers FREE SHIPPING on all orders.http://www.thirdgen.org/techboard/im...milies/nod.gif |
