Mustang Fuel Tank Install
22 gal. tank. It's tight but it fits and doesn't rub anywhere. Nuts are welded into the inside of the square tubing. All mounting nuts are welded to truck frame for easy installation. Fuel tank is mounted above lower frame lip instead of below like all of the others that I have seen.
http://i227.photobucket.com/albums/d...7/IMG_0734.jpg http://i227.photobucket.com/albums/d...7/IMG_0737.jpg http://i227.photobucket.com/albums/d...7/IMG_0744.jpg http://i227.photobucket.com/albums/d...7/IMG_0745.jpg |
Looks real nice.
That looks slick. What year mustang did that come from and where did you pick that new on up from? I think that is the answer to my problem.
Originally Posted by 4finger
(Post 7638999)
To clearance the underside contour of the rear-most part of the bed the removed truck crossmember must be slightly modified and re-installed upside down. I welded mounting nuts to the inside of the rear crossmember for easy installation because it's a PITA to get your hand and a wrench up inside the frame to bolt the crossmember back in. I will be finishing the tank install this weekend. I have a real sano idea for the fuel door in the rear of the bed. |
'Stang tank...
Nice install man....that looks great!
Perfect size too.... Do you remember the EvilBay-user-name ya scored that tank from???... I've been lookin' for somethin' for my '56 Effie and cant decide between the Mustang and he Bronco tanks...:-banghead... Sort of the same units...just lookin' for a good deal...}>... |
Mustang gas tank
Originally Posted by rockher_man
(Post 7650012)
is that a long bed or short and how do you bolt the box on there is two bolts that use the rear crossmember to bolt thru from under the bed that are not accessable from the top inside of bed and can you show the front area where the fuel line and float assy is (view). Very nice set up kinda curious as to the filler hole setup is going to be done.
Originally Posted by 390428cjt
(Post 7658228)
As to your question about the rear bed bolts, the crossmember that used to run between the rear leaf spring mounts is now relocated all the way to the rear of the frame. It has been slightly modified and is installed upside-down to accomodate the contour of the underside of the rear of the bed. The nuts that bolt down the rear of the bed are welded inside the crossmember because there is no room to get a wrench inside the frame... http://i227.photobucket.com/albums/d...7/IMG_0756.jpg The nuts that mount the crossmember are also welded to the inside of the crossmember... http://i227.photobucket.com/albums/d...7/IMG_0768.jpg The rear bolt hole is for the rear bed mounting bolts... http://i227.photobucket.com/albums/d...7/IMG_0769.jpg I have not finished the fuel line plumbing or the sending unit wiring. The sending unit is on the front of the tank behind the diff... http://i227.photobucket.com/albums/d...7/IMG_0770.jpg http://i227.photobucket.com/albums/d...7/IMG_0772.jpg http://i227.photobucket.com/albums/d...7/IMG_0767.jpg |
nice one more question,, how is the bumper brackets going to be bolted on as there doesnt seem to be enough room to get at the brackets bolts to the frame?
(Post 7659485)
(Post 7659485)
Tanks...
OK...that was bad...
Man...that install came out sweet! Thanks for the info... Now I got some more options... |
Originally Posted by BradyCouchman
(Post 7659689)
that is what a weld in roll pan is for.....atlest that is what i would do.
Nice job,good looking project you have there.
Got the fuel door almost done. Gotta grind off the spot welds and make some more adjustments...
http://i227.photobucket.com/albums/d...7/IMG_0804.jpg http://i227.photobucket.com/albums/d...7/IMG_0806.jpg http://i227.photobucket.com/albums/d...7/IMG_0807.jpg http://i227.photobucket.com/albums/d...7/IMG_0812.jpg http://i227.photobucket.com/albums/d...7/IMG_0815.jpg http://i227.photobucket.com/albums/d...7/IMG_0818.jpg |
