gas tank sending unit
Hey guys,
The in-cab gas tank sending unit is toast and I was wondering if I could still get the OEM original. The part number on the unit is: C4TF-9275-S This is off my 1967 M100 All help is appreciated. Thank, John |
Originally Posted by zenmaster
(Post 7602974)
Hey guys,
The in-cab gas tank sending unit is toast and I was wondering if I could still get the OEM original. The part ID number on the unit is: C4TF-9275-S The float is made from two pieces of copper soldered together. The solder breaks down, gas seeps in, the float slowly settles to the bottom of the tank. COAZ9202B .. Fuel Sending Unit Float / Available from Ford Fits: ALL 1957/79 cars/trucks. MSRP: $7.41 // FTE sponsor y2kfordparts.com price: $5.34. --------------------------------------------------------- C1TF9276A .. Fuel Sending Unit Gasket / Available from Ford Fits: 1957/77 w/In-Cab fuel tank sending unit. MSRP: $5.82 // y2kfordparts.com price: $4.19. --------------------------------------------- y2kfordparts = Millennium Ford in Seattle WA. -------------------------------------------- D7TZ9275G .. In-Cab Fuel Tank Sending Unit / Includes Float and Gasket / Obsolete Fits: 1961/77 F100/750 // D7TZ9275G replaced: C1TZ9275K / Last MSRP: $95.15. COTTAM-WALKER FORD in Taos NM has ONE. MILLER OBSOLETE PARTS in Binghamton NY has ONE: 800-546-7278. GREEN SALES CO. in Cincinnati OH has THREE: 800-543-4959. (High Buck!) BOB ALLEN FORD in Overland Park KS has FOUR: 800-676-0675. No other Ford Dealer or obsolete parts vendor has any! The Ford dealer in NM will prolly be the cheapest. |
NumberDummy,
Thanks for the info! I'll call that shop in New Mexico to see how much it is. I'm fairly sure it's pooched - here is a pic: Pictures by zenmaster2009 - Photobucket scroll down on the left to my album "gas tank sending unit " and have a look...I'm still waiting to hear back from the rad shop out here as to the cost of cleaning the old tank. It's pretty bad, and I may have to buy a new one. That's going to put a big dent in the budget, I'll bet. Thanks for taking the time, John |
For some reason mine will only read up to a 1/2 tank when full. With the sender out it reads the entire range, and the float has been replaced. The replacement float was from lmc and wider that the older one by about 1/2" or so, could it be getting hung up and not going all the way to the top of the tank? There is not a lot of room at the top (narrow).
Mine is worse than toast, it's gone!
So I just bought a truck, discovered the gas smell was coming from a missing fuel sender, and can't seem to find a replacement. Or I have found too many that "say" they are the right part, but look different.
I have a 71 f-350, with an in-cab behind-seat tank, that holds at least 15 gallons (i've put that much in it). The hole where the fuel sender unit was is about 2 inches across and has 5 screw holes around it. Anyone have any ideas what I am missing? I looked at the C1TZ-9275-KR part photos online and it looks like it might be right. Any help would be appreciated. Thanks in advance. Richard |
Yeah, that's pooched all right. Time to cruise yards looking for parts, or hit the classifieds here and at FORDification.com - The 1967-1972 Ford Pickup Resource
I used to use a hardware store yardstick as a fuel gauge...way cheap and it never fails to read accurately. |
Originally Posted by rhubler
(Post 11707233)
I have a 71 f-350, with an in-cab behind-seat tank, that holds at least 15 gallons (i've put that much in it). The hole where the fuel sender unit was is about 2 inches across and has 5 screw holes around it. Anyone have any ideas what I am missing? I looked at the C1TZ-9275-KR part photos online and it looks like it might be right. Any help would be appreciated. Thanks in advance. Richard Joe |
Hi Joe
Thanks for the info. Sounds like we have the same need, so I'll see how your fix works. I've also started trolling the junk yards around here so may luck out there as well. Richard |
Tank sending unit
(Post 11758748)
Hi Joe
Thanks for the info. Sounds like we have the same need, so I'll see how your fix works. I've also started trolling the junk yards around here so may luck out there as well. Richard Bottom line: a $39 part that is NOT OEM but works great and is delivered quickly. Good luck, Joe [IMG]https://www.ford-trucks.com/forums/p...ctureid=100117[/IMG] |
(Post 11707233)
I have a 71 f-350, with an in-cab behind-seat tank, that holds at least 15 gallons :-huh (i've put that much in it). The hole where the fuel sender unit was is about 2 inches across and has 5 screw holes around it. Anyone have any ideas what I am missing? I looked at the C1TZ-9275-KR :-huh part photos online and it looks like it might be right. No such thing as C1TZ-9275-KR .. the add-on R is a repro parts sellers 'made up' part number, prolly refers to: Reproduced. One might find the DOTZ-9002-A tank in 1961/69's, as Ford replaced the tank used in these trucks with this tank in 1970 for use as a service part replacement. --------------------------------------------------------------------------------------------------------------------------------------------------------- Same info as in post 2, except the sources that have the sending unit have been updated, since that post was typed 6/13/2009: D7TZ-9275-G (replaced C1TZ-9275-K) .. In-Cab Tank Fuel Sending Unit / Obsolete Applications: 1961/77 F100/750. SMACKOVER MOTORS in Smackover AR has ONE = 870-725-3961. NELSON FORD in Martinsville VA has ONE = 888-869-3167. NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746. GREEN SALES CO. in Cincinnati OH has SIX = 800-543-4959. |
old thread here, i know, but was wondering how that ebay sending unit is working? or if anyone found out why the sender(s) seem to work fine out of the tank, but not in?
