quick answer please. where is the pcv hose
going to seafoam my truck.. can someone tell me where the pcv hose is on my 99 f250 v10
Before you do that, whats the problem with it?
i am going to seafoam it.. just to try to flush some carbon out of it that is robbing my of MPG, throttle response etc.
The PCV is on the passenger side valve cover.
I don't mean to tell you what to do but I'm about 99% sure that will not help you. |
i thought i would give it a try still.. can you be more detailed on the hose i should use. there are several hoses on the passengar side.. do you have a pic
Its a valve that it plugged into the valve cover on the passenger side of the engine. If you pull it out of the cover you'll see that it is a pcv valve. It should be the only hose going into the cover. You can then pull the hose off of the pcv valve and use it to administer the seafoam.
ok so just to make sure.. on the passenger side of the truck there is only one hose going into the value .. i pull that end out and into that end of the hose i can pour the seafoam..
aside from seafoam, what you do recommend i do, let me also add that right after the seafoam I am installing new plugs ..anything else i am overlooking. |
In order to seafoam I would normally pull the cable off the brake booster line, I've never done it through the PCV hose.
1. Seafoam 2. New Plugs 3. New Airfilter 4. Clean MAF 5. Clean Throttle Body 6. New Fuel Filter 7. New PCV Valve 8. Change fluids over to synthetic (Engine/Diffs/Transfer Case/Transmission) All of the above would assist in restoring previously lost throttle response. |
You can use any hose that pulls vacume to put Seafoam in your engine.
I use a smaller hose connected to intake manifold & add 3ft. of vacume hose so I can slowly feed the liquid in to engine without having the engine kill because of a major vacume leak. I just pinch off the flow when the engine wants to kill out. I also don't like to race the engine speed with a major vacume leak as I'm old school and afraid of running too lean and I fear burning up a valve during the process. |
The two biggest things for throttle response and MPGs on the V10 are cleaning the MAF and changing the fuel filter.
BEFORE you go and pour a solvent into the intake of your somewhat-perfectly-running engine, go and do all the normal tune-up stuff first. If you're afraid to do the plugs, at least remove the COPs, make sure there's no moisture or dirt in the holes, and check the boots. Then use dielectric grease around the tip of the boot where it meets the plug, the top of the boot where it seals to the COP and then around the seal area where it seals to the head. |
I was wondering how you got such a high post count....
LMAO!!! |
Originally Posted by Ballswedge
(Post 7592151)
LMAO!!! |
It was a joke.
(Post 7592407)
It was a joke.
Krewat grew up on FTE. he used to be krewat. Now he is uppercase.
