clutch pedal return?
just got my f-1 out for the season. the clutch pedal doesn't come all the way up. i've tried to read the motor manual to see if there is a clutch return spring on the pedal. i see a retracting spring but it seems to be for the brake pedal. is there a clutch return spring on the pedal? right now my retracting spring is just hooked over the pedal shaft, is that right or where should it hook? i can't tell from the motor manual. thanks, dick r
