Fog Lights
I Have a 99 Ford F-350 Dually It didnt come with fog lights will i have to buy harness and fog lights to put the factory fog lights on my truck or do the trucks come pre-wired from the factory ?Thank You
There is a short harness that is probably not included stock. Plus if the truck wasn't ordered with fog lights, your light switch probably doesn't have the position for them. If you have to have stock lamps, you can pick up (I think it's 9005/6) pigtails for the bulbs and build a harness very easily with a pair of relays and a switch if you want one. For ease though, you might consider wiring them so they turn on with the low beam lights.
Hey Thanks Very much!
would HIGHLY recomend aftermarket lites over the stock ones.....
better, cheaper, more choices & more easily found.... just a suggestion.. |
Just to confirm, there were no wires or bracketry in my early build '99 that did not include factory fogs. And the switch did not have the pull out to activate fog light feature.
I have installed my own switch, relay, and wiring, but am still looking for the "perfect" fog lights. The tule fog here in the winter is famous for its density.... Function is far and away number 1 priority (I'm thinking HID), but it would be nice if they would fit in the stock bumper cutouts. Any one have ideas? |
