Peter94 |
04-25-2009 10:41 PM |
Wake up Call!
Well,
As the title of this post says wake up call. I can laugh about this now because no one got hurt and nothing got damaged. But anyway, was working on my brothers truck today, putting valve cover gaskets on. I sprayed them off over the garbage can with brake cleaner, installed new gaskets, and put the valve covers back on. Then I proceded to tune it up with plugs/wires/cap/rotor. After he was about to leave, we metioned to me that his exhaust was loose. I took a look underneath, and sure enough, broken hanger. So I grabbed the piece of 1/2 rod that I had, and looked for a good place to cut it off at. I then decided to lay it across the garbage can (long rod) so that about 3-4 feet was hangin off of it. I only needed about a 4" chunk. So I fire up the torch, get about half way through cutting in and then BANG!!!!!!!!!! The garbage can erupted into a 6 foot tall flaming inferno. I had forgotten about the brake cleaner that I had sprayed almost an hour earlier. The can was full of fumes, and it exploded with fire. Burnt all the hair off my right arm, and singed the hair on the right half of my head.
Thankfully I was smart enough to have installed multiple fire extinguishers throughout the building, and the fire was out just as fast as it has started.
BUT A WARING TO ALL, EVEN IF IT IS LATE AT NIGHT, AND YOU ARE TIRED AND YOUR BRAIN IS NOT FUNCTIONING AS IT SHOULD BE, PAY ATTENTION TO WHAT YOU ARE DOING!!!!!!!!!! THINK!!!!!!!!!! INSTALL MULTIPLE FIRE EXTINGUSIHERS!!!!!!!!!!! SOMETHING!!!!!!!!!!!!!
Just thought I would pass along the info and offer a fair waring to everyone.
