New injector - how long to settle in?
I recently had my #6 and #8 injectors replaced (re-man from Ford) from my friendly neighborhood traveling diesel mechanic. These were found to be bad during a no-start issue. He also replaced the injector harnesses and valve gasket. So - after lots more troubleshooting and work (mostly thanks to FTE) the truck starts well and runs ok. WIth my new AE my #8 fails the CCT, and has an average of 5% rotational velocity. THe #6 is 0. Does this mean that the injector is bad, or does it need to settle in. I have traveled about 400 miles. No fuel mods. Buzz test sounds fine.
Thanks, |
Do you have the updated grey cps? If so there have been a few people having trouble with cct on #3 & 8. I'm not to sure about #6.
Oh, and I have a "brand new" gray CPS, that I swapped out with another "newer" gray CPS because I thought it may be bad. It was my ICP.
Did he put in a long lead (AE) injector, or a regular AD injector in the #8 hole?
As long as it's running good, Don't worry about the rotational velocity. To keep those injectors like new go to POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners Watch those videos , they will last a long time. Also, I would use a good additive at every fuel stop. I use Delphi, It removes water 10 times better than Power Service. or Diesel Kleen:-bigparty
I runs well except, yesterday I put the petal to the metal getting onto the freeway, and the SES light came on. That has happened in the past, but typically only when pulling a trailer going up a hill.
I watched the videos for injector tune-up. About 300 miles ago I changed to synthetic oil, and removed the quart of old (well changed about 1000 miles ago) oil from the HPOP. I did not do it 3x. Should I go in and do a change again (on the HPOP side)? I use an additive to remove water, not sure the brand, I will check. It may be Diesel Kleen.
Originally Posted by 89BlackBeauty
(Post 7351653)
Originally Posted by powerstrokeforever
(Post 7351582)
I thought about overboost as well. I do not have gauges (I want them, but....). I do have an AE, can I measure boost with AE? I also would not think I would get overboost with a fully stock truck.
Also, could Exhaust Back pressure play a role? I have another post asking for that info:
https://www.ford-trucks.com/forums/8...ml#post7346994. |
Oh, and I have a "brand new" gray CPS, that I swapped out with another "newer" gray CPS because I thought it may be bad. As long as it's running good, Don't worry about the rotational velocity. To keep those injectors like new go to POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners Watch those videos , they will last a long time. Should I go in and do a change again (on the HPOP side)? As for the SES light coming on during a WOT run, pull the code and post it up. AE should be able to pick it up. Even if the light is off now, the PCM still stored the code (unless you unplug the batteries). |
I'm not calling anyone a lier. But, I was a heavy diesel mechanic for 5 years. The stuff Bill hewitt is talking about in a lot of those vids on Powerstrokehelp is good information. I have two diesel shops around me that like the idea, one of them has been building injectors and pumps for fifteen years. The choice is yours, I continue to listen to the experts! If oil flowed from the oil pan so well, Why did Navistar put an oil Resevoir on the HPOP?:-whud I know on my 7.3 it takes me three changes to get clean oil out of the HPOP Res. If it flows so well, why then is it not clean after a regular oil change? :rolleyes:
I pulled the code at had a P1211 inj control pressure higher/lower than desired (engine running) that was thrown when I did the hard accelerating. I recently replaced my ICP sensor, and the wiring harness is good. Does that mean my IPR is going? Also, I checked the #8 again today and it was 4.5 to 4.8 a little better than last time.
(Post 7354210)
