maximum trailer towing
I have a 70 f100 360 + c6. 2000lb hitch truck is 4400gvr
I am getting a campertrailer this summer. what is the max size i can tow and do i need to upgrade the hitch? |
tbejr:
Sorry, I can't give you exact numbers but I did want to say welcome to the site. First thing I can tell you is to forget about the bumper for a hitch use a receiver hitch, much more stable. Secondly, I don't see any reason you couldn't pull a 4000 to 4500 lb trailer. Jim. 2000 F-250 XLT SUPERCAB 7.3 PSD 4X4 AUTO, LIGHTED VISOR, ROLL TOP COVER, BLACK AND BEAUTIFUL. I JUST LOVE A FORD TRUCK. |
[font size="1" color="#FF0000"]LAST EDITED ON 04-Mar-01 AT 01:38 PM (EST)[/font][p]I also have a '70 F100 with a 390 C/6 and 3.50 gears, gvw 4,400# and I've done quite a bit of towing with it. I think your brakes will be your limiting factor. I have manual drums, and once they get hot, they're pretty useless. I have a 24' pontoon that weighs in at about 3000# with the trailer and the truck has no problem with it at all. I also have a 26' camper that I bought last summer that weighs quite a bit more than the pontoon. I'm going to pull it with my '79 Supercab (disc brakes and a 4bbl 460). The most I've towed with my old '70 was 8,100#. Way too much weight! It was a '73 F150 4x4 on a 2,700# trailer. I needed more gear in the rear and much better brakes, but I got the job done safely and slowly. I think a truck used for towing should at least have a class 3 receiver hitch. I just found out that if I have an accident while towing either of my toys with the bumper hitch, my insurance agent won't cover the accident. Time to go buy a good hitch!
Jason Kendrick 1970 F100 Custom 390/C6 1978 F150 Ranger Lariat Supercab 460/C6 |
Thanks for the response. Now how much weight can i haul in the bed of the truck. the f100 frame looksw so wimpy in comparison to
my old 66 ford f250? |
I believe 1000 pounds is going to be about it for the F100. Remember that it is less than a true half ton. usually the trucks weight subtracted from the gvwr will give you the capacity. Look on the door sticker for a gross axle weight rating. It should list two different ratings for the front and rear. Like posted above, install a good class three reciever hitch. I highly reccomend Draw-tite, they are a bit pricey, but you get what you pay for. Make sure that whatever you buy has at least surge brakes...and for a camper, electric brakes with a controller in the cab is best. If you aren't sure what to get, any reputable draw-tite (or other brand) dealer will be able to help. I can't stress trailer brakes enough..especially with a vehicle that has barley enough brakes to stop itself. (if you have the cash, front disks are a fantastic upgrade. Good luck
Captain Tim Bland 1986 F150 SWB 4WD 300 I6 1bbl 3.08's NP205 4speed |
just thinking of a tent trailer that folds out. isint that light enough with stock equptment+hitch upgrade.
