Installing pyro in the Y- collector
Has anybody installed the pyro in the Y collector on the up pipes so they could read both banks? or would it be possible to do so? Thanks guys
It would do you no good. We have a divided collector...
http://inlinethumb07.webshots.com/41...600x600Q85.jpg Light blue arrow... Just stick it in the drivers side manifold and drive away. I have both a right and left side pyro, there the same all the time. |
What Joe said... the collector is a lot harder to get to anyway and the shavings will fall down into the uppipes if you do that. Also you want the EGT reading as close to the cylinder as possible.
Driver side up pipe, right after manifold.:-banghead
Garsh Darnit!! i totally forgot they were divided!:-banghead ugh o' well thanks for the reminder
