Oil pan torque sequence, 302
have a felpro one pc gasket for a 302. anyone have a diagram for the sequence of torqing the oil pan bolts and torque values of bolts, small & large. thanks once again.
There's no torque sequence for the pan. Just cinch everything up evenly and don't overtighten a pan or valve cover gasket.
The one piece gasket is the way to go. I just put one on my 302 and tighten them up as close to the same as I could. No leaks at all. Like he said just don't over tighten them.
start in the middle and work your way out to the front and rear. Off the top of my head, the torque value was around 10 ft-lbs.
thanks much
