F350 ABS light
is there a way to flash the ABS light to get a code ?
I have a light on and want to see what code it is Thanks !! |
Check engine light, or ABS light? The ABS light should flash a code when the key is first turned on. Also the year model and engine you have would be helpful.
not check engine light, its ABS light. It is off until the truck starts moving, I suspect a wheel sensor, not sure which one
2000 F-350 superduty V-10 Auto 4x4 |
