snugger brackets from MidFifty
Has anyone used the snugger type rear bumper brackets from Midfifty? I ordered a set last week to hopefully tuck the bumper some. I was just wondering if anyone has had any experience with these. Thanks.
Rodney, I trial fitted and painted a set of those black...though I"m using a pros-pick bed(it is a nice bed though..) , If I can remember right, the brackets pulled the bumper up to within 1/2" of the rear rail or bed crossmember. I liked the way it looked so much, I then went up front and whacked off about 2 1/4" off the frame horns,re-drilled mounting points, to tuck the front bumper in also...
I recommend the Mid50 brackets for a little different look. They are also a quality part, heavy enough to take a hit...but I'd be pretty pissed if that happens...LoL! You will be happy with them. |
I'm going to remove about 1 1/2" from the downward angle of my rear bumper bracket and re weld which will pull it up and in.
I think the bumpers on these trucks looked good tucked in. I am planing on tucking my front bumper and going with a rollpan on the rear with a old bumper some how bolted behind it.
I have them on my 55 the only issue I have is you can't use the license plate bracket with the tucked bumper, other than that I like it.
Originally Posted by raerjim
(Post 7245733)
Rodney,
I put a set on my truck last year. They work fine no problem. If you want I can post a picture tomorrow. Hey Got a buddy up this way looking for a 56' cab do you have any good ones back there around Ardmore? |
Originally Posted by cmoritz
(Post 7245694)
[quote=tacson;7246164]Rodney,
I put a set on my truck last year. They work fine no problem. If you want I can post a picture tomorrow. Hey Got a buddy up this way looking for a 56' cab do you have any good ones back there around Ardmore?[/quote Thanks Don, the tailight bracket may be a issue after seeing all these replies (Thanks everyone) but I can handle that. I know where there are 2 complete 56 trucks about 2 miles from the shop, one looks solid but a long wheelbase and the other is flatbed but the top looks like someone did the cha cha on top but the bottom end, hood, and grill looks tight. I will check on them when I get back into town. |
I'm always looking for a chance to show off. Here is a picture with the hugger brackets.
https://www.ford-trucks.com/user_gal...140165.520.390 |
Originally Posted by B/B ford
(Post 7246746)
As Wayne mentioned above tail lights aren't an issue but the license plate bracket will not work I ended up placing my plates on the tailgate. Awsome ride Wayne.
I tried cutting down my original brackets which were terribly pitted, but wasn't satisfied with the way it sat. I ordered the huggers from Mid Fifty and am completely satisfied with the quality and fit. They are being powder coated as we speak. Just make sure to attach the bumper to the bracket before installing unless you have an extremely small hand (ask me how I know!) I too cut the frame horns back for the tucked look up front. I am running a rool pan and rear bumper so mine is kinda different. Still in the building stage but that part is finished and looks great. Hope this helps. ps I'm old and technology challenged or I would attach pictures! Have fun, Steve
1 Attachment(s)
Here is my tucked bumber with license bracket. Not the best shot but couldn't find the good one. Joe
Pictures do tell a thousand words(or give a thousand ideas)...
Wayne,..What did you do, or how did you mount your tag? Custom bracket mounted to bottom of bumper? I"ve been tossing around a couple of ideas on building one,...but so far everything that"s gone thru my mind and onto paper in a sketch is WAY to over built...Not "simple" enough...yours looks gooand is the right place...I"ll drill into the bottom of a chrome bumper if need be.. Joe, What did those tailites come off of? what type stands? Looks Great!....just a little differentalso it"s a little hard to tell from that pic, but are those rear fenders widened?? ...thoughts from the darkside, fuel for the cliff jump... Chris |
