engine locked up
i have a mid 80s 460 in front of a C6 in my 1970 F350, So i was driving down the freeway (constent speed of 60) when all of a suden it started to make a pownding noise, almost sounded like a belt split and was thumping on something. so i pull over and it made the noise untell i turned it off (i almost thought it might be a flat tire that split). so i get out and cant see anything worng with the truck. so i get it towed home so i can work on it. well i go out and check everything i can see, the dizy cant move and when i canked it (twice, without the dizy cap on) the rotor turned and everything else turned too (alt, power steering, water pump). no pullys were loose. so then i decide to see it will start and see if i can hear it and find the noise. well the starter will engage the fly wheel but will not trun the motor over. so i put a breaker bar on the crank and i could not get it to move at all. and i really tried to get it to. so now my question to all of you, what do you think it could be or how could i fine out without having to really pulling the engine apart?
any help will be great. |
the engine when i first got it home would crank but now it will not, not even by hand with a breaker bar.
the other question i have is if i do need a new engine what way would you all sugest? new crate egine, long block? |
Dump the oil, see what you can see in it. If you can't see anything there, you'll have to pull the pan.
i am not sure i can pull my pan without pulling the motor, but i think i will drain the oil tomorrow.
Pull each plug. Each one will tell its own tale. Good luck.
i did pull them all and nothing really looked all that off, i can take pictures of them but not sure if it would help or even if it would come out right.
i also pulled the starter and the flex plate doesnt look bad. in the AM i will drain the oil. |
Maybe a bent valve, take the valve covers off and see if anything is obviously out of place.
Originally Posted by orng1
(Post 7237997)
i can see it now i will tare down the whole engine in the truck before i find what is wrong.... |
Sorry to hear your having issues, let me know when your going to work on it. I may have time to lend a hand or at the very least hang out and keep you company.
Brady- Oil pressure, oil temp and water temp gauges were fine before this happened?
the water temp was fine, oil pressure was fine (as good as the stock gauge works), dont know the oil temp. but it didnt look/sound/smell like it was over heating when i opened the hood on the side of the freeway.
You did all that wiring, and didn't put good gauges in? tsk-tsk. lol. Like has already been said pull the valve covers and then the pan. You will probably have to raise the motor to get the pan off. good luck
ok all oil drained and both valve covers off. here is what i found:
http://i319.photobucket.com/albums/m...s/PICT1553.jpg http://i319.photobucket.com/albums/m...s/PICT1555.jpg http://i319.photobucket.com/albums/m...s/PICT1557.jpg http://i319.photobucket.com/albums/m...s/PICT1565.jpg this is the biggest thing in my oil...there was not much of it. (the blue is a glove and the little brow item felt like grim or dirt or metel shavings http://i319.photobucket.com/albums/m...s/PICT1569.jpg i couldnt find anything wrong or that looked different then the rest of anything. to see all the different pictures go here: Ford Trucks pictures by bradycouchman - Photobucket |
As the process continues you will end up taking the timing chain cover off to see if the chain broke. You have have a busted gear or chain and a piston is up against a valve.
You could loosten all of the rockers to see if they will free up a piston. Once all of them are loose are removed, it should isolate the valve train from the equation. If the engine turns after that, you can then remove the timing chain cover to reveal what went wrong. |
Brady I have a rbuildable core for you in El Cajon if you end up needing one.
