'55 T5 conversion
hello all! im new to the forums here, so please be patient with me. i know sometimes people get frustrated with the new guy. im about to tackle a t5 conversion on a 55 f100. it currently has a 289 6 bolt motor in it with im guessing a 303 tranny. this is a friends car so i dont the all of the details in and out. i have done a t5 conversion in a ranchero recently so i know a little of what is involved. my questions are as follows:
will a 4speed bellhousing from a '65 289 be sufficient? i have an adaptor plate for the t5 already from california mustangs i believe. im assuming i will have to use the clutch fork to go with that bellhousing. there is already a hydraulic setup on the truck so im not worried about adapting that to work. is there any modification needed for the floor as far as shifter clearance/location goes? i know the t5 is a little taller than the 3 speed. ive read about the s10 tailshaft being the desirable setup in the 53- setup, what about the 55? what is involved with switching the tailshaft out? is that involved? if i remember correctly, the t5 and the 3 speed input shafts are splined differently. im guessing i would need a new clutch for the t5 splining. what about the mount for the t5? is there much modification needed for the crossmember? what about driveline angle? is that a factor? i have read about a guy named "dick" on the forums who is supposed to have a good write up on this but i have not been able to find it. any help would be greatly appreciated! hopefully i dont scare you all off with many questions. thanks again Tim |
Welcome aboard!
Bump to the top. |
To eliminate any guesswork, I'd look at using the 302 Mustang GT bellhousing and T5 with the proper balance flywheel (289's balance) and clutch for proper spline engagement. Then it's a matter of adapting the S10 tailshaft onto it so that the shifter locates close to the right spot.
I've been researching this same thing for sometime and I have a few links to different writeups on what you are doing. The 2nd link contains links to tons of info. I hope these help.
Ultimate T5 Swap Article The Ultimate T-5 Swap Article This one has just about every T5 line on the net. TRANSMISSION - T5 Tech Links - THE H.A.M.B. |
