Bed light
First post, second day of ownership of 2008 F150 long bed. When ever I turn the truck off the bed light stays on for several minutes. How in the heck do you get it to go out; change the time period for staying on, how, I have found no switches or any visible means to turn the darn thing off. (Truck came with no owners manual.):-banghead Tks
https://www.fleet.ford.com/maintenan...ls/default.asp
put in your model year and select the F-150 it will open up the current revision owners manual for your truck. I'm too lazy to look through the manual right now, but hopefully you will find the answer in there |
Try; Genuine Ford and Lincoln Mercury Parts & Service
select your vehicle From page 91 of the owners guide Autolamp control (if equipped) The autolamp system provides light sensitive automatic on-off control of the exterior lights normally controlled by the headlamp control. The autolamp system also keeps the lights on for approximately 20 seconds or, on vehicles equipped with a message center, you can select a delay from 0–180 seconds, after the ignition switch is turned to OFF. • To turn autolamps on, rotate the control counterclockwise to automatic . • To turn autolamps off, rotate the control clockwise to off. If your vehicle is not equipped with a message center, then the auto lamps can be programmed manually by: 1. Start with the ignition in OFF and the autolamps selected. 2. Turn off the autolamps by turning the headlamp switch to off. 3. Turn the ignition to ON. 4. Turn the ignition to OFF. 5. Select the autolamps by turning the headlamp switch to automatic. Steps 2 through 5 must be performed within a 10 second period. At this point, the headlamps and park lamps will turn on. 6. Deselect the autolamps after the desired autolamp delay time (maximum of 3 minutes). At this point, the headlamps and park lamps will turn off. |
Thanks found a copy of users manual on e-bay for $10.00. Also found that the light is controlled by the dash intensity panel light. So if the dash light is set to off the bed light goies off when the door is closed. Tks Sabbot
Wish I had all of the neat stuff, but that stuff is on my wife's Lexus LS. I just get the dump run truck.
Tks Sabbot |
