antifreeze
I was wondering what you guys have been using for antifreeze? I have the gold color in my truck and i am due to change. I thought it might be best to use the same one so i dont have any odd problem with a reaction of some sorts? We had that issue come up at work with some big Detroit diesel generators . Thanks Joe
You're right to be cautious about mixing different chemistries! And there are more than enough exceptions to the rule that you can NOT just go by color. You need to know exactly what was in it and refill/replace with the same, or thoroughly flush it.
Me? I dumped and thoroughly flushed out whatever was in there and refilled with good old Peak ethylene glycol based antifreeze - the green stuff. And change it every 2 years. That is what is in all my other vehicles, so less chance I will accidently screw up something. The ethylene glycol is compatible with the materials in the V10 gasser, not sure about the diesel... |
check the owners manual and probably on the radiator or under the hood. Most of the Fords are using the motorcraft gold, yellow in color. You will not want to mix it with anything else, best to just get it as it is already premixed.
Isn't the difference between the two antifreezes used by Ford, is that one is extended life, and the other isn't?
That's why Prestone states their Extended Life antifreeze mixes with any antifreeze in any car or light truck? |
Diesel engines have different issues with cooloant than gas engines. For example: The high compression causes cavitation issues in the coolant passages on the outside of the cylinder walls, which leads to pitting and hot spots; Also, diesels cause more dropout of silicate which can cause gelling in the coolant. I would stick with the gold or another major brand made for diesels.
antifreeze
I read some place on the site that the Zerek G05 meets the ford spec for the Gold coolant but i cant find that now? That it might even be where ford gets it from? Just a thought Joe
in all honesty, why not just spend the $16.00(thats what I paid at ford) for the right coolant and be done with it?:-banghead
Originally Posted by renoduckman
(Post 7198561)
..oops I just noted that you were asking about G-05, and you're right. Zerex has a page that shows applications for their formulas, and G-05 is shown as Ford gold. edit: here's the page http://www.valvoline.com/pages/produ...asp?product=10 I would not mix anything else with the G-05 *if* that is what you've got in there. George |
Originally Posted by slowmans
(Post 7202991)
rep points for that one! that is the best advice! |
Originally Posted by mwsF250
(Post 7198658)
Originally Posted by Furian
(Post 7203234)
I have the 5.4L engine. I think that I'll take mwsF250's approach the next time that I change my coolant. I know that I can completely flush what's in there now and go with the "green stuff." My concern is not the cost of the Motorcraft Gold coolant but its availability, especially while traveling. I'd hate to need some coolant and have to start looking for a Ford dealership because no convenient store sells the type coolant I need. Just my opinion...
I just don't see any negatives to staying with the gold G-05. George |
thanks
Thanks for the advice. Will go with the Go5. The cost is not the issue, i just didnt want to screw up! Ford probably gets it from Zerex. Joe
