Help with Fuel Line problem on '92 F250
I was changing inline fuel filter with retaining clips on inside using retaining clip tool - the output side came off with no problem but the input side couldn't get it off.
I looked inside the end that I removed and saw that one retaining prong was bent upward. I bent back into place and attached it back to the filter. It would not snap onto the filter nipple. It does not leak nor did it "pop off" all this time so... I have several questions:
Update to post:
Originally Posted by cjlafa
(Post 7174296)
-6 AN to 5/16" hard tube adapters 640860
-6 AN to 3/8" hard tube adapters 640850 these are the ones i am using and you only need 5-7psi of pressure at the carb they just replace the factory fittings and you run -an hose up to the carb they are made by russell performance here is the only picture i could find that might show you how i did it but i'm running an efi pump and bypass regulator http://i36.photobucket.com/albums/e1...d/DSCN0335.jpg |
