YouTube - Ford 300, cam
This has the Cliffy valve cover. It took well over 3 months to get it, after it was ordered. Going thru comments, I got a lot of 300 bashing, but about 90% was positive. I took the video, it's my nephew's rig. |
Nevrenufhp--
Nice valve cover--and nice engine. Can I ask what type of exhaust you have on that rig? |
On my 67, it's a Hedman heddder(bad idea on a Bumpside). and 2" to 2 turbo muffs, then dumps under the truck.
The 72 in the video has the same heddder, but 2.25" pipes with 2 Flowmaster 50's. No crossover pipe or anything. It does beat V8s too. |
One time I saw a Honda beat a V8. A 305 TBI fbody from the 80's... and your point is :-D
:-fire:-fire:-whudOo.
Originally Posted by F-250 restorer
(Post 7044727)
I forgot to mention the Clifford 6=8 polished aluminum valve cover, which, of course, instantly boosts the hp by 20!! at least.
Oo.:-down:-fire:-whud |
one day when i have time money and space i want to build a carbed 300 just for kicks cause that valve cover dont work for efis lol :(
Originally Posted by 9.ford.5
(Post 7049035)
Hey, you work for a big rig company, right? I just learned how relatively small the motors are in these big rigs. I couldn't believe it! The motor in the Kenworth my dad drives is only 375 CI's. I'd like to know the bore and stroke stats. :-hijacked Jacking done. |
Originally Posted by 6CylBill
(Post 7049492)
:-hijacked
Originally Posted by CampSpringsJohn
(Post 7049528)
Most semi trucks state the size of their engine by horsepower, not ci's. And they typically use liters today too when stating the displacement. Is it a caterpillar, cummins, or detroit engine? Most of the engines in todays semi's run between 12 and 16 liters.
The gear ratio's are similer to trucks, too. Obviously the ring and pinion are the same, but the final drive is still referred to "3.83" or whatever. I thought that was interesting, too. http://www.youtube.com/watch?v=jMisS...e=channel_page |
(Post 7051402)
No, he meant CI's, I believe. It's a Cat straight six. It has 500 horsepower twin turbo.
The gear ratio's are similer to trucks, too. Obviously the ring and pinion are the same, but the final drive is still referred to "3.83" or whatever. I thought that was interesting, too. YouTube - Pop's Rig my dads 2001 peterbilt 379 has a cat c15 single turbo pushing 625 hp. dont know how much torque hes got but its in the range of 1800 im thinkin never heard of dyno on a semi lol hehe yeah sorry bout the :-hijacked if i remember monday i will try to confirm the #S for ya :) |
actually theres some cool vids on youtube of truck drags out at a truckfest in quebec theres these 2 trucks out there that work daily but are totally built...i think they are both c15 cats but one pushes 2000hp and the other is 2400hp watch these 2 trucks drag...with over 100000lbs of weight behind them watch the frames twist and the front wheels come off the ground its sick
this tan and red peterbilt driven and owned by nicholas gagnon (the one on the left) is the one with 2000hp YouTube - Nicolas Gagnon Rodéo du camion 2007 this is the 2400hp. western star driven and owned by eric bouchard YouTube - Eric bouchard show de boucane camdrag matane this is what you get when you put em together 8D YouTube - Éric Bouchard vs Nocolas Gagnon remember each of these truck is loaded with well over 100000lbs 8D |
(Post 7049528)
(Post 7049528)
(Post 7049528)
(Post 7052329)
Originally Posted by Econoline 150
(Post 7053670)
Yes that's true, Cummins 250,290,335,350,400 were all the same 855 cid size, just different setups for power. Them old Detroits (53,71,92s) were listed by cid per cylinder and were avabile in 2,3,4,6,8,12 and 16 cylinder setups depending on model. The Cats werent listed in displacement they listed the model like the 3208 was a 600 something cid V8
(Post 7056460)
Hey thanks for the info! I think you guys must be right. Suren't it's not a 375 CID I6. I've seen it and it looks mammoth. It has to be more like 800 CID.I forgot about the 18 speeds, too. That helps get the load going down the road too.
