Pics of IWE solenoid
3 Attachment(s)
hi all, after digging through some threads about IWE's and solenoids, i found that a few people were curious as to what the "new" solenoid looked like. So, since i had to replace mine today, i figured i would post some pics of the 2 to compare.
New style: (Ford p/n: 6L3Z-9E441-A) Attachment 221167 Side by side: Attachment 221168 Old style: (you can even see some ice on mine) Attachment 221169 |
is this a dealer only item or can i get it from auto parts store and what do they run? thanks for the pics by the way
..don't forget the "bone yard"...allways take a sample with you
HAHAHAHA its the same deal with a plastic cover!!!!
i can make that in 5 minutes ... but whats the point! |
The point is, that water gets into the solonoid on the early model. The shield prevents that, but you could make something up yourself.
I had to change mine today after reading the very informative forums...thanks to all who post vg info....my 2005 did not have the shield... local dealer here in Saskatoon said part from 2006 would fit c/w shield $34.00 +tax....2005 part # no shield 84.50 + tax.
Thanks All |
HOLY CRAP......the dealer charged me 16 bucks for the new part....or wanted 34 for the other one.....
I have been getting way too familier with my 2004 FX4 4 wheel drive issues. I believe my original soledoid is working as I get about 20 lbs on both actuators when not in 4 wheel drive and atmosphere in 4 wheel drive.
I can get the front hubs to engage if a draw a vacuum on the port on the right hub that runs between the two actuators (which I would assume should be atmosphere when engaged). I am guessing the actuator cannot engage the hub because it is dirty or worn out. Can somebody help a brother out? |
im curious is this for the switch on the fly 4wd or is it for the floor shift 4wd too?
just bought this solenoid from a dealer. expected to get the version with the cover/new mounting bracket. did not! got the same looking one as before??? insatlled it anyway and it ended up not being the issue!!!! now i need to dig into all the lines and the vacuum box behind teh battery i just read about in a different thread.
Sneaky parts guy trying to clear his old parts out!
You might want to fab a cover of your own to keep water/ice off of the new part. I'd try a cut out from some smallish plastic bottle bottom. The bottle bottom would be the top of the cover...and a cutout at the front for the plug-in. Is this what your using?... Most like it. https://www.ford-trucks.com/forums/836438-everything-you-wanted-to-know-about-the-iwe-system-and-then-some.html My truck needed the solenoid AND IWEs replaced to fix the problem. http://www.f150online.com/forums/2004-2008-f-150/360269-iwes-removal-replacing.html Tool list and pics. twfish, All the (this forum year group) 4x4s have the solenoid. All the 4x4s are "shift on the fly" (for 4HI only), even the floor shifter types. All the 4x4s have an electric shift motor on the transfer case. |
[quote=60DRB;11005232]Sneaky parts guy trying to clear his old parts out!
Not sure I ordered it through an online dealer and even questioned why the one with the bracket was less the one w/o. Dealer had both and thepack appeared to have a date code from this year??? I think I will try to fab up some out of some sheet Aluminum just in case. You might want to fab a cover of your own to keep water/ice off of the new part. I'd try a cut out from some smallish plastic bottle bottom. The bottle bottom would be the top of the cover...and a cutout at thr front for the plug-in. Is this what your using?... Most like it. https://www.ford-trucks.com/forums/836438-everything-you-wanted-to-know-about-the-iwe-system-and-then-some.html Yep that is the one i had looked at. My truck needed the solenoid AND IWEs replaced to fix the problem. http://www.f150online.com/forums/2004-2008-f-150/360269-iwes-removal-replacing.html Tool list and pics. Great write up any idea what was going on with teh IWE that caused you to have to swap both? did you ebnd up doing both IWE's quote] |
- I suspect the (old style/original) solenoid failed due to the water/ice issue. I "discovered" the left front was having a problem when I heard the classic high-speed grinding noise intermittantly in 2wd. While trouble-shooting, I discovered the right front IWE held no vacuum at all... when I took it off I found the spring was broken/jammed, the grease was black and dried, and the diaphram was torn. The left side IWE had a very slow vacuum leak too. AFTER I relpaced both IWEs the noise returned. I replaced the solenoid and "presto", works like new for almost two years now. Both of those threads have my worried questions and triumphant remarks strung though them. (and several other guys' too.)
...the IWEs are NOT submersion proof. I'm not sure what caused the right front IWE failure. I'm the third owner and the truck only had 44K when I got it. The truck has no other issues of any kind. |
I just had to put a new IWE in my truck, I put some silicone arount the top to seal it up a little better, hopefully that doesnt cause other issues.
Hey guys, has anyone replaced their u joints, the factory "shop"manual talks about them being stake can someone elaborate on this.
