2008 Expedition Keyless Entry Code
Just bought a new rig and I love it. However I neglected to ask what the keyless entry code was before I left the dealership. I checked the owners manual to no avail. There's no little card - nothin'. Looked under dash both drivers side and Passenger. Any suggestions would be welcome.
Thanks :)8D |
I know that they are not in/on the 2007 expeditions so I would bet that they are not on the 08's either. You probably have to go to the dealer to get them to get the code for you.
Today I was told by my local dealer that they couldn't pull the code from the VIN and needed to access the PCM to pull the factory code! All this for the low low hoilday price of just $45.
Is this true, it has to be read from the PCM? Or is my dealer all JACKED! Thanks in advance. L1 BTW - 07 Expy EB. |
Yeah that is correct. Have to read from PCM. It takes 2 minutes but they make $45-$75 when they do it.
I would go back to the dealer you just bought it from since there was no card. I would think that since it's a new purchase, they would take care of you.
But then again I know how some of these dealers dealers can be:-banghead |
They should have done it for free.
I bought my 08 used from a dealer and they pulled the code for me for free.
Kelly |
Originally Posted by MeŠiCX
(Post 10586860)
x2 - do your research - the search link is your friend.. I have an 08 and the code is on a sticker inside the passenger kick panel Minimal tools if any required, check the link above. |
Good info to know!
08 expedition
I found my code on the back of the fuse panel.
my 2007 had the code behind a module behind passenger foot area. took a couple minutes and a screw driver. The codes is there.
