Shakey doors on supercab
For those of you with supercab 150s do you find your doors shake when you go over a railroad track or very bumpy road almost like they are not fully closed?
Has any one fixed this issue with success? Thanks |
i am glad that you brought this up. i thought it was the NE Texas dirt roads
Sounds like the striker plates need to be bumped in just a little. Since it closes using the rear door, it may need the plates bumped in just a bit also. I dont notice it on mine,,,, but i do notice the paper thin sheet metal flex inward just a little on the fronts. Embarassing. I think someone on a bicycle could hit the door and cause a nice size dent. Apparently theres not much if any body goop between the cross bar in there and the outer panel. paul 05 scab
door shake
If the rear doors on mine are not shut tight they do rattle. If you grab hold of the top of the rear door and pull, it won't move if shut tight.
Has anyone adjusted the strikers? If it is an easy thing I would like to handle it myself.
I have tried the "slamming little door" technique but it doesn't seem to work and I hate slamming the heck out of the door every time. |
The strikers are easy to adjust. They are held in place with 2 Torx head bolts (size 45 I think) all you have to do is mark where the striker is now, loosen the bolts and slide the striker back.
Strikers out of adjustment will exaggerate the problem. Supercab unlike crewcabs have no solid post between the doors, you will get some rattling/shake on really rough RR track/roads,ETC.due to the design...It is the nature of the beast..
Originally Posted by slparry
(Post 6909119)
If my rear doors are not shut tight then they rattle, i just make sure i slam the rear doors when i close them. I know they are not tight when i shut my front doors when the door slams it jiggles at the connection of the two doors a little. When they are shut correctly the door closes firmly. Try slamming your back doors and see what happens.
