Need to replace fuel filter retaining clips
Hey all. Been a while for me here, but I'm back. The last time I changed the fuel filter on my 99 F150 5.4L, I learned the right way to do it ... because I did it the wrong way. I didn't know I needed a special tool and mangled the spring steel clips inside the ends of the fuel line. I bent them back best I could and put it together. It's been fine for years but I want to change the filter again now and would like to put new spring steel clip retainers in there. Any idea where I can find them? Dealers have told me that I can't order just the clips and the local parts stores are clueless.
Thanks, Mike Gregory |
Originally Posted by Mike-G
(Post 6694816)
E9UZ9B307A 6 TABS 13MM O.D
E9UZZ9B307B 5 TAB 10.5MM O.D Ed |
fuel filter spring steel retaining clips
Ron,
I looked at the local parts store and they had some Dorman fuel clips but none of them looked anything like I remember mine looking. The ones in the store had nearly straight fingers and were not a continuous ring. From what I remember on mine (going back a couple of years), mine were a continous ring with the barbs kind of bending back like a claw. I found a plastic one from Dorman that fits 1/4" filters. This went on the filter I was buying but I have no clue as to if it will go in and or stay in the fuel line. Still looking for help. Thanks, Mike Gregory |
2 Attachment(s)
Originally Posted by FTE/PARTS-GUY
(Post 6694878)
E9UZZ9B307B 5 TAB 10.5MM O.D Ed Here are pics with the clips installed. Attachment 221155 Attachment 221156 |
Originally Posted by ncranchero
(Post 6695147)
Not to nitpick, only in the interest of accuracy, but I think there's an extra "Z" in the 2nd part number. If you're dealing with a Ford dealership who's Parts Dept can't come up with these clips the numbers you give them had better be right!:rolleyes:
I tried, to no avail, to find a picture of these little buggers to post. I have some somewhere but of course I can't put my finger on them. you are correct,I fat finger it. E9UZ9B307A E9UZ9B307B Ed |
(Post 6695189)
Thanks all. I give er' a try in the next week or two.
Mike |
... Adding to an old thread, Dorman in their OE Solutions line makes these as replacements for the 5/16" (800-007) & 3/8" (800-008) fuel lines. The kit containing both sizes is 800-017 is handy when changing fuel pump or dropping the tank as you get both pressure & return line clips / retainers.
They list them for line sizes 10.5mm (fits 5/16" coupler), & 13mm (fits 3/8" coupler). NAPA had the best price at $3/ three pk. The numbers are easily found on part store websites. |
Good info, thanks!
