Glow plug relay wiring diagram
Does anyone know where I can find the wiring diagram for the glow plug relay on an early 99 PSD?:-huh I'm not sure if mine is wired correctly..... As always, thanks in advance for the info and support :-X25
I'll post this link to help but I'm not sure if the early '99's are the same as the rest.
Welcome to guzzle's Stancor GPR replacement Mod Web Page Look at the picture caption "Remove the Old GPR" |
1 Attachment(s)
Originally Posted by Ponyboychris
(Post 6671872)
Originally Posted by Smokin'
(Post 6672008)
'99's are the same. Only difference is lack of AIH relay.
Thanks for the pic, mine is very similar. With the ignition on, the "#3" wire has positive voltage, which would be contrary to it being a ground through the PCM??????
1 Attachment(s)
I hope this helps
85 is red |
Originally Posted by IM1096
(Post 6672689)
3 & 5 could be reversed and the relay will still operate. With key on you will see battery on both with one lead to ground. You will be reading the voltage through the winding. You need to lift the wires off the posts to isolate them and then read their potential with key on. Edit: Nice diagram Jim. Does what I said make since? |
Originally Posted by PaysonPSD
(Post 6672778)
Edit: Nice diagram Jim. Does what I said make since? Thanks! |
Thanks for the diagram and info, helped me understand it a little clearer,,,,,, As always this forum is a wealth of great info and help!!!!
Sorry in advance for the necropost, but on this page, http://api.viglink.com/api/click?for...d%20Web%20Page , On the diagram "Remove the Old GPR", what is the purple wire on the output terminal?
3 Attachment(s)
Originally Posted by subcaptian
(Post 14583409)
Sorry in advance for the necropost, but on this page, ... On the diagram "Remove the Old GPR", what is the purple wire on the output terminal?
