DIY Black Headlights Done...again lots of pics...not 56k friendly
Finally got them done and installed...I have had plenty of time the last few days to work on them :-X05
Parts List: Krylon Fusion Flat Black Paint Out the Door Price...under $10300 Grit Sandpaper 2 tubes of outdoor RTV silicone sealant Painting Masking Tape Oven at 250F The Look is awesome IMO. Stock Shiny Light http://i199.photobucket.com/albums/a...s/IMG_5883.jpg Stock Shiny Light Torn Apart http://i199.photobucket.com/albums/a...s/IMG_5886.jpg Stock Shiny Light Prepped For Painting http://i199.photobucket.com/albums/a...s/IMG_5896.jpg Not So Shiny Light Now http://i199.photobucket.com/albums/a...s/DSC01722.jpg Headlight Installed - Pass Side http://i199.photobucket.com/albums/a...s/IMG_6031.jpg http://i199.photobucket.com/albums/a...s/IMG_6032.jpg Headlight Installed - Driver Side http://i199.photobucket.com/albums/a...s/IMG_6033.jpg http://i199.photobucket.com/albums/a...s/IMG_6034.jpg Full Frontal - Before :-missingt http://i199.photobucket.com/albums/a...4/IMG_4755.jpg Full Frontal - After http://i199.photobucket.com/albums/a...s/IMG_6036.jpg now to install this thing http://i199.photobucket.com/albums/a...t/IMG_6038.jpg |
Wow that looks good. Those AS blocks are great. I have had them on for about a year now.
Professional looking job!
one question i have is
how did you get the light apart b/c arent they glued togetheir heat gun razor blade ?? |
Nice job!!!
Looks awesome man. Black lights really set off white trucks like yours and mine.
Originally Posted by silver05fx4
(Post 6635947)
how did you get the light apart b/c arent they glued togetheir heat gun razor blade ?? put headlight in for 10 minutes at a time. carefully pry the lens from the base...reheat periodically to keep the glue hot and pliant be patient and you'll get there eventually :-drink |
Looks great! I was going to buy a set that was black, but that sounds easy, and most of all, cheap enough that I may do it myself! Good work
Looks really good. I love the black headlights, however, i have a red truck with the chrome front and rear bumper, and i just dont think the black would look right on mine. The "shiny" stock lights look like they fit i guess.
im thinking of doing mine silver to match my truck ...i think it should look good
1 Attachment(s)
Let us know if you have any issues with traped moisture or leaks. Looks good!
Now you need a set of these to go with it. They look good on a white truck. |
I've had mine done now for 4 months on my pickup zero issues with moisture. I have had my civic's lights done for 2 1/2 years with zero problemes also. if you do it just make sure to clean out all of the old glue where the two peices seal. one side is a channel, U shaped and the other side just sits in. i used a clear silicon with the tapered tip and filled the channel then sat the other peice in (if your careful enough when you take them apart you, the clips wll still hold the 2 halves together while the silicon dries.)
thanks 98greensi...but not for me. I actually really like my OEM FX4's for now
but once my rubber wears out, I'll either buy the Moto Metals 20" rims...or get the 22" Harley wheels. I finally saw a pair in person yesterday on a Black truck with the Orange stripe...I'm in Love. and the chrome/black HD wheels would fit my truck perfectly IMO somewhere down the road I'll have 20" rims with 35" tires
Originally Posted by 98greensi
(Post 6644030)
Wow that looks pretty good great job
(Post 6641786)
http://img69.imageshack.us/img69/551...ghts002qn0.jpg |
