Trouble code on my '06
Okay, any of you Ford techs (yes, I'm hoping you see this Chris (redneckcowboy)). Have a check engine light on the Super Duty. Pulled code P0460- Fuel Level Sensore A circuit. Anyone with a clue?? :confused:I posted this in the SD thread too.
It's junk....sell it to me dirt cheap.
-Jake |
prob needs a new sending unit or you over filled it.
Talked to the dealer, their thinking the sending unit also. It's still showing level at the dash. I'm taking it in on tuesday to get it looked at.
Originally Posted by jseim44
(Post 6609168)
-Jake :-missingt |
[quote=97nukeford;6606030]Pulled code P0460- Fuel Level Sensore A circuit. Anyone with a clue?? quote]
P=part O=out 4=for 6=six 0=ounces of beer! :) |
Ha! Very funny Dallas!!
pat,
the fuel sender went south on you bud. i used to get those codes alot at the tranny shop. it will trigger a check engine lite but it won't throw the computor into limp home mode. ford ranger |
Originally Posted by FORD RANGER
(Post 6613327)
pat,
yep,
you can tell when its in limp home mode the lite will be on and the tranny will start off in a higher gear and won't shift. even if its not tranny related. but that isn't the case this time. pat if its still under warranty take it back to the dealer and get it taken care of! the race is on! at the dega! its on abc guys! just opened a beer. and watchin'. later ford ranger |
(Post 6616632)
yep,
chris,
that 100,000 mile warranty only covers the engine, not the hole truck! now depending on the type of warranty you have! now if its an 06' or older yes the power stroke is still covered. under 100,000 miles. unless you get the extended warranty, then your covered. ford ranger |
I know hat isn't and is covered.
chris,
i know! i worked for a company that had a fleet of fords and the dealer made me a rep. for warranty and recall and stuff like that. i worked in a fleet shop and sometimes ford will do that! ford ranger |
I know as well, I am a Ford Senior Master Tech
