Rear End
While browsing through the specs for my Expedition EL, I read that it should be equiped with the 3.73 rear end. Then I read that, that, rear end is discontinued. If I remember correctly, I should be able to discern from the vin what rear end I have. What would be the code for that?
16= 3.73
15= 3.31 |
would those numbers be in the vin or elsewhere?
I looked at the vin and neither a 15 or 16 appear. |
Originally Posted by williamsplumbing
(Post 6508781)
Second line from the bottom on the VIN plate. Here's mine:
Axle = 16 = 3.73 http://img.villagephotos.com/p/2004-...22-data_ex.jpg Can anyone translate the other data? I figured out the 119" wheel base. -- Chuck |
(Post 6508509)
If You have the EL then, You have the 3.73 Rear Axle Are You saying that You read that Ford is Discontinueing the 3.73 Rear Axle on the 2009 EL Models?:) |
Originally Posted by chuck s
(Post 6511307)
Axle = 16 = 3.73 http://img.villagephotos.com/p/2004-...22-data_ex.jpg Can anyone translate the other data? I figured out the 119" wheel base. -- Chuck ext pnt= exterior paint code int tr= interior trim code spr= spring code(1st 2 digits front springs, last 2 digits rear springs. thats the extent of my knowledge! |
All EL's have the 3.73 Rear Axle
