where to find white door handles
I have looke dhigh and low and all I can find is paint to match.
Is there a secret club for white door handles? |
Paint to match? Junk yard? don't know!
I was thinking of doing the same thing, plastic enamel like they paint the pillar pods??? Never seen same colored door handles except black, would look nice.
look on ebay..when i got my SS handles he had colored handles..not sure if they were painted or color plastic..i also dont remember the sellers name...that was 3 years ago..
I'll take a look, thanks Ron....
dppi has some grey ones and blue ones on their website. give them a call maybe they have white as well. Diesel Performance Parts - Home
1. Go to hardware store
2. Buy white Krylon Fusion and masking tape 3. Go home 4. Mask door (clean the handle with something if you feel so inclined to remove the oil and such) 5. Paint handle Total cost- under $10. |
Originally Posted by big poppa pump
(Post 6401659)
I have a few cans left over, I just hate to have it look cheezy. Maybe a primer 1st? |
Originally Posted by superduty4x4
(Post 6401965)
I can't speak for the enamel, but the Krylon fusion will stick really good. I've seen where someone painted a panel on a dirt bike with the stuff, later crashed and cracked the panel, and the Krylon Fusion paint was still holding. The guy took the two pieces of the panel and stretched the paint out quite a bit... I was impressed. With the enamel I'd do at least a little prep work to make sure it sticks.
(Post 6401997)
It's simpler than all that, guys. I have an '03 Eddie Bauer Excursion that has the white handles. Just call a Dealer parts place (like FTepartsguy or Y2K Ford parts, both being site sponsors) and ask for the Eddie Bauer Excursion handles. Then you will have both the right color match AND a smooth, non-textured finish (painted black handles will still have a slight texture even after they're painted).
What you're going to have to do, though, is call them on the phone. I spent a few minutes hunting through their online parts catalog and the door handles don't show up. I have personally worked with Kenny at Y2k Ford Parts on several occasions, and he's great to work with. Either of the above referenced sponsors should be easy to work with, though. Just go to their website and give one (or both) a call. |
Originally Posted by F250_
(Post 6402083)
It's simpler than all that, guys. I have an '03 Eddie Bauer Excursion that has the white handles. Just call a parts place and ask for the Eddie Bauer Excursion handles and you should have not only the right color match, but it will also be smooth instead of having that slight texture the black ones will still have even after they're painted.
i had to go to the dealer and get excursion handles cause they are smooth and paintable.You may get lucky and they have them painted in stock. I wasnt so lucky
(Post 6402026)
I got some fusion paint in the garage(different color) from painting some plastic lawn chairs and the stuff held up good. I'll check it out, thanks Chase. Sorry for the Hi-jack Fraalan, taking all this down?:-drink
I did try the fusion and the enamel last night. Neither matched but the fusion did bond better. You can see the color difference from any distance. I did call ford yesterday and they only have paint to match (at least the 2 dealers that I called. I have another trick up my sleeves, stay tuned. |
call
Mark Craig Diesel Performance Parts, INC. 411 Allied Drive Nashville, TN 37211 866-455-7788 Phone 615-834-9923 Fax he has mixed colors at $5 each (front only) I got a black and a blue , the grey looks dimpled like the black yes $5 ea I found some rears at a reasonable price here partstrain.com |
Wow! Only $5 each? Is that just the handle portion only, or the entire body of the handle ?
EDIT: I just called them and all they have left are the front door handles with the key holes, and all of their remaining stock is dark blue in color. Too bad! I was hoping to get four rear door handles so I could eliminate one entry point potential for some slumbug thief who may want to take a ride in my truck one day. |
These should be the part numbers for the Oxford White handles from the Excursion:
https://www.ford-trucks.com/user_gal...id=194729&.jpg Unfortunately, I'm not sure which are front and which are rears. Of course, if you want to eliminate the key holes, you need two sets of rears only. Pop |
As has probably been stated before, Ford has been trying to get away from stocking uniquely painted parts and have been transitioning to "paint to match" parts wherever painted replacement parts are called for. These handles, I'm afraid, were a casualty in that move.
I already had purchased a set of blue handles when they were available for my truck, which is Ford's True Blue metallic color, but at $5.00 a piece I went ahead and ordered two more fronts just in case mine get attacked by some worthless thief. For those who are looking for painted handles and aren't against using the ones with the keyholes in them, I recommend you snapping up a pair of these. They will be the smooth finish and you can paint them to whatever color you need. They're bound to be cheaper than the "paint to match" handles you'll find at the dealer and you can sand them and repaint them a different color. Then just buy your rears from the dealer or online supplier. For that matter, you could even put these $5 keyed handles on the rear doors and only have $20 invested in the set. You'd have to make the call whether you're willing to have the keyed handles on the rears and also would have to get locks from somewhere to put in them but, darn, at $5 a handle it'd be hard to go wrong. |
Oh great - something else that I "must" do to the truck. I never did like those cheap looking/feeling black handles (at least that's what I'm going to keep telling myself).
FWIW, I don't think the painted handles are much improvement, if any, over the build-quality of the standard black handles. They just look much nicer. As others have recommended before, you could save even more money by just painting your black handles. The minimal hassle of dealing with the textured finish would be the only concern.
2C3Z3622405AAQ and YC3Z7822404AAJ have been superceded by 6C3Z3622405AAE, and the new number is now used for both left and right doors on the front.
2C3Z3626604AAV has been superceded by 6C3Z3626604AAG, and is the Right Rear outside handle. 2C3Z3626605AAV has been superseded by part number 5C3Z3626605AP, and I can't tell which door handle it is, but I suspect it is the Left Rear handle.
Originally Posted by SpringerPop
(Post 6403955)
i get the eliminated the key holes, but what if your battery goes dead?
or if you lose your key fobs? |
I have wondered the same thing.
Originally Posted by Fraalan
(Post 6446692)
Gotcha, Aaa On The Way With A Slim Jim.
Not A Bad Idea. |
(Post 6401978)
I was thinking of using appliance spray enamel.
I would personally just paint them instead of replacing them, I love the look of painted door handles and 04-07 tow mirrors painted like the Oxford White and Gold King Ranch trucks. I am sure a paint shop could do them for a fair penny ;).
My truck is white and the door handles are black of course. Was thinking of painting mine until someone on here mentioned that the black handles look good with the white truck, breaks it up a bit, undecided now???
If I was going to paint the handles I would simply take them off the door and paint them. Remove the door panel, a few more nuts and a couple of rods to unlock and the handle is off. I removed one of mine when I replaced the door lock actuator. It was much easier to put the latch back on with the handle out of the way. Also with the handle off you probably could sand it down with a fine grit, prime it fairly thick to fill in and paint. It would probably end up very smooth looking after that.
Wahoo, double post, gotta love the timing out stuff...
The white or chrome handes, are just normal black handles with a cover with adhesive.
The driver door should be left without the lock cover, in case..... I know this, because a friend of mine had "white" handles, and you can feel behind, that its basically a white cover, glued on. Sure enough, I go home and check mine, same thing. |
Wow, I wasted some time here. Keeping my black handles. They work well with my silver/black motif.
Well i finally got my ****e covers on and they look great.
Except of coure I left them in the garage over the weekend as i was out of town. Sure enough on of the chillins got into the box and put a nice little chip on the drivers handle (of course). but they look great and the match the factory paint perfectly and they were a breeze to put on. PICTURES ARE COMING SOON! |
I Wonder Why THE WORD "White" Was Edited Out?
Obama Isnt Even President Yet. |
