y-pipe
Hello to all. I am getting ready to have my up pipes changed and the ford mechanic I was talking to said I should also get a y-pipe because more than likely the bolts will break off. Does anyone have suggestions where I could pick up one. He said the dealers are way back ordered. Or if anyone has a shop they would recomend I would appreciate it. I forgot, I have a 2000 PSD.
Thanks Roger |
maybe bill's wife could help?
or Shawn brown "ragin diesel" or Nate, Strictly diesel. either one of them should answer your post on azpsg if they have anything. Bart |
Hi, The wife says Sanderson Ford would be her first try....
Wife works for McCandless, or I 10 International. She is a Parts Gal for them |
Diesel Engine Repair Scottsdale Arizona, Cummins Diesel is a great place to call and ask, they're located out in Scottsdale, and can probably get your part if it's in town anywhere! Talk to Nate or Mike there
Roger....the more I think about it, the more it bugs me and I had to do a follow up post. I see absolutely NO REASON why you need to replace your Y pipe when it's not broken yet. I'm wondering if this mechanic doesnt have the proper tools, and has broken those bolts off in the past while trying to replace up-pipes. With the right tools, there is no reason you shouldn't be able to keep what you've got to work with the new uppies. Have you had this mechanic do work before for you? I suggest ya call Mike or Nate at Strictly and pick their brain a bit about this......they are the experts. Good luck, and let us know what happens!
Thanks to all for the ideas. No I have not had this mechanic do any work for me before. I will give Nate a call today. Thanks again
Originally Posted by 1eagle
(Post 6399494)
Thanks Roger |
also Roger.....try posting this in the 7.3 forum, you'll get a TON of responses! :-X22
i've have one of the pipe on order now for over 2 months.
ed |
Thats not a good sign! If you really need 1 :-banghead
I am confused, maybe it is because I am a girl but why do you need to get another Y pipe when there is nothing wrong with yours?????? Why is the mechanic so sure the bolts are going to break off? Sorry if I sound like a dumb girl.
its a good idea to have a back up part...if it breaks, you put the part in, if not, send it back
if it breaks and there is no back up part...the truck could sit idle for months waiting for one a matter of better safe than sorry...but a little penetrating fluid and some tlc...the bolts shouldnt break |
I understand keep parts on hand just in case. I like to have extra on hand when ever I can but IIRC people have done the up pipes without needing a Y pipe. I was just curious.
Yep, just being prepared. If I get the pipe I will not need it, if I do not get it the bolts will for sure break off and I will be up the creek. Thanks al for the input. Have a good one.
Hope it goes nice and smoth for ya Roger!! Keep us updated.
