223 6 cylinder specs.
does anyone know where i may be able to find specifications on a 1958 223cui 6 cylinder engine, such as rod and main bearing clearance, bolt torque values and such?
The 1958 Ford Truck Shop Manual is the Best place to start looking, but this might help in the interim.
1958 Ford 223 Inline Six Engine Specs GENERAL SPECIFICATIONS Model designation: Mileage Maker 6 available in all models Wheelbase: all models The valve location: in head Bore and stroke: 3.6250 x 3.600. Piston displacement, cubic inches: 223 Compression ratio: 8.60 Maximum brake horsepower@RPM: 145 @ 4200 Maximum torque pounds foot,@RPM: 212 @ 2400 Normal oil pressure pounds: 45-50 TUNEUP SPECIFICATIONS Ground polarity and voltage: negative-12 Spark plug: Champion 870 Spark plug gap: .034 Distributor: Point Gap Inch: .025. Cam angle degrees: 35-38 Firing order: 153624 Ignition timing: Damper has five timing marks covering range from TDC to 9° BT DC in 2° increments set timing at 4° with standard transmission and 6° automatic transmission Timing Mark location: damper Idle speed RPM in neutral: 475 Compression pressure@cranking speed minimum: 150 VALVE SPECIFICATIONS Running clearance: Interior: .019, hot or cold. Exterior: .019, hot or cold Valve seat angle degrees: 45 Valve timing: Intake opens degrees BTDC: 17 Exhaust closes degree a TDC: 9 Valve spring pressure lbs. At inches length: 161@1.39 Cam Lobe lift: take measurement at top end of pushrod Intake:.273 Exhaust:.273 Stem clearance Intake: .001-.0024 Exhaust .0023-.0037 Stem diameter standard Intake: .3416-.3423 Exhaust: .3403-.3410 ENGINE TIGHTENING SPECIFICATIONS Spark plugs foot-pounds: 15-20 Cylinder head bolts foot-pounds: 65-75 Intake manifold foot-pounds: 23-28 Exhaust manifold foot-pounds: 23-28 Rocker arm shaft brackets foot-pounds: 45-55 Rocker arm cover foot-pounds: 2 - 2-1/2 Connecting rod bolts foot-pounds: 45-50 Main bearing bolts foot-pounds: 95-105 Flywheel to crankshaft foot-pounds: 75-85 Vibration damper or pulley foot-pounds: 85-95 COOLING SYSTEM AND CAPACITY DATA Cooling system data Quarts, no heater: 15 Quarts, with heater: 16 Radiator cap relief pressure: 12-15 Thermostat opening temperature: 180 Fuel tank, and gallons: 20 retractable hardtop: 17-1/2 gallons Engine oil Refill quarts: 4; add one quart with filter change Transmissions: standard: 3 pints; with overdrive 3 pints; automatic 9 quarts Rear axle, pints: 5 1/2 STARTER MOTOR SPECIFICATIONS Part number: FAR-11002A Rotation: clockwise, as viewed from the drive end Brush spring tension, ounces: 48-56 No load test: amperes: 80, volts: 12, RPM: 4800 Torque test: amperes: 550, volts: 5.0, torque pounds foot: 15 1/2 PISTONS, PINS, RINGS, CRANKSHAFT AND BEARINGS Ring and gap: compression:.010, oil:.015 Wrist pin diameter: .9121 Rod bearings: shaft diameter 2.298-2.299: bearing clearance:.0004-.0023 Main bearings: shaft diameter: 2.498-2.499, bearing clearance:.0005-.0025 Thrust on bearing number: 3 Shaft end play: .004-.008 DISTRIBUTOR SPECIFICATION Part number: B7A-12127H, B8A-12127J Rotation: clockwise Cam angle degrees: 35-38 Breaker point opening, inch: .025 Condenser Capacity, Mfds.: .21-.25 Breaker arm spring tension, ounces: 17-20 Vacuum advance data: Inches of vacuum to start plunger movement: .55 Inches of vacuum for full plunger travel: 3.38 Maximum vacuum advance, distributor degrees: 12 1/2 |
col flashman, thanks for the reply, just the info i was looking for.
No worries, mate!
Glad I could be of service. |
Looking for valve cover torque limit
Have a 1956 F-100 with 223. Looks like oil is leaking from the valve cover so going to put a new gasket. Cannot find the torque limit anywhere.
Hi brettkroeder,
Welcome to FTE. I don't remember a torque value for the valve cover hold down nuts. Make sure you replace the rubber grommets that go around the hold down studs. Tighten the nuts until everything seats and the new grommets are starting to squish out, the nuts won't feel very tight. Just FYI, in the future it is probably better to post a new question as a new thread if you have a change of subject like this. |
Fred, You're alive. Maybe I haven't been paying attention, but I haven't seen you in a long time. It's good to know you are still around. You've been a great help to me and many others. I hope all is well with you.
I've found that very gradually tightening down the valve cover is helpful. I make the nuts hand tight. rest bit, then tighten some more, and so on. Jim |
