Trailer hitch fit ???????????
Will a Reese trailer hitch from a 1989 f150 fit on a 1993 f150?
It's the same truck except for the front end sheet metal.
Thanks for the info.
Originally Posted by Bursch
(Post 6370040)
yes, 80-96 all the same and I hear the frame width is the same on the highboys as well. |
i Just put a resse hitch on my '95 F-150 and i can hardly tell its there . i will say if your hitch is adjustable like mine i'll give you a far warning to be prepared to drill some 1/2 inch holes, have a 19mm around, and Finally don't loose your religion :-X09when you think the hitch won't clear the spare tire bracket on the passenger side. Just push the hitch back a little bit and your good. Goodluck on your project
I got it put in. I had to remove the bumper and drill the holes. It did take a while but I was not giving up. Thanks for all the help guys.
