Exploded view of 55 272 Distributor
I cann't find a pic of a 55 ford distributor. I finally pulled mine out lastnight and found a wire that had a bad spot on it. It's the wire that connects to the points and runs under or out to the coil. This wire connects to the condenser to. I need to look at this wire better and I need to find out if I can get one to. Thanks
Scott B. |
The wire that runs from the top of the points to the insulated bolt on the side of the distributor case has bit me twice, once in my F-2's flat six, and again in my panel's V8. It's a very easy thing to overlook but a very part to check, and the truck won't run if it's broke or shorting out.
Replace it with a rubber one (napa has them, lw??) you will never need to change it again.
[IMG]https://www.ford-trucks.com/user_gal...id=187443&.jpg[/IMG] |
Thanks, I didn't realize they made one. I'll have to check out the next time I go to NAPA, which will this week sometime.
