Originally Posted by f_ford_custom
(Post 6318364)
is it sluggish below 2000? around 3000? or everywhere? I ask because that 1405 is a rich carb, I got a neighbor with a 396, bigger cam, ported heads, longtube headers, and 6al ignition. even with all of this, she runs rich until about 4500. We changed it out for a 750 tuned for fuel economy and it really wakened up. You dont even smell fuel when it warms up now.
I'm still in the tuning stages so.... Madmike33 |
Madmike33: My problem is solved. It was the wrong flywheel. Love what previous owners do. I bought the thing not running and with bad tranny. Time will tell how how much damage was done to bearings before the tranny crapped out. Good luck with yours.
Originally Posted by gfw1985
(Post 6325281)
Madmike33 |
have you played with the timing? I'd try backing it off a little, see if it helps. Maybe advance, but sounds kinda like a few degrees into spark knock, since HP spark curves pull off about 3000. have you put on a timing light at 3500? should be about 32-36 deg advanced.
(Post 6344732)
Madmike33 |
The instructions will give you step-by-step instructions, but basicly just take off the dizzy cap/rotor, and the springs are right there on top. The insrtuctions will also tell what colors will come in where and when they'll be at full advance. Your kit probably came with an allen wrench if you've got adjustable vacuum advance.
(Post 6348174)
Madmike33 |
