what to do next
I have a 2006 F-250 2x4 with the 6.0. So far I have put on the Bully Dog tripple dog w/outlook moniter (I know the SCT is supposed supposed to be better, but I got a good deal on the bully dog), Banks Ram-Air intake, and I have orderd 5" MRBP exhaust the one w/o the cat (hasnt came in yet, Cant wait). What should I do next. I was thiking Banks techni-cool intercooler, but I dont know. Should I do head studs before I go any futher, or should I do someother performance mod. Also my EGR is unpluged, My EGT's run around 1442 deg or so with the peadle to the floor. The bully dog kept defueling so I raised the limit to 1500 deg. Is this Ok? Is there something else I can do to get the EGT's down, or should the exhaust take care of the high EGT? I know that this is alot of questions, but I dont know much about diesel performance, and you guys are the best.:-X25. as always thanks for your input.
Scotty |
anyone have a suggestion.
ok, I might be wrong, but I'm pretty sure your EGT are a WEEEEE bit high.. keep that temp up for long ya' might have a swiss cheese piston..
If it were me, I would ditch the Bully Dog and go with some "custom" tuning. You'll be surprised at the performance difference you'll get out of something like a DP Tuner (Jody Tipton) over those name-brand options (Edge, Bully Dog, Banks, etc.).
As far as EGTs go, it's a combination of heat and time that will cause you problems. Conventional wisdom says that you can run at 1250 degrees all day long without a problem, but once you see sustained temps in excess of 1300 damage can occur. With that being said, I bury my pyro in a 1/4 mile run. Having the temps in the 1600+ range for a matter of a few seconds won't cause any damage. Standing on the throttle while towing and seeing sustained temps over 1300 is a no-no. I would also add some in-cab gauges (boost and pyro at the least, and tranny temp if you have an auto). The factory boost/tranny temp gauges aren't that accurate, from what I gather. If you want to make more power that tuning alone will give you, I would go with injectors next. This will require the proper supporting mods including studs and tranny upgrades. Do you have an auto or manual? |
I have an auto. the 5" exhaust sounds awesome and help alot with egt's. when Im towing my trailer it stays around 750-850 at 75 mph. it will still get up to around 1450 or so if I hammer on it and stay on it for awhile. My bullydog shows trans temp and I have a factory boost gauge. I guess I can look into getting after market gauges. I think Im eventually get an sct tunner, but for now im going to go with arp head studs and bigger trans pan.
