Cowl Removal Question F-250
I need to replace a windshield washer jet on my 1992 F-250 King Cab[drivers side] and have all of the screws out of the cowl and can move it around good on the drivers side but it's tight on the passenger side and i can't get my hand in there.How do i remove the antenna [at which end] so the cowl will have enough clearance for my hand to get in there to remove and replace the jet?Thanks.Any tips to make the job go well will be appreciated.Also,when reinstalling the rubber cowl seal should i use silicone or weatherstrip adhesive on it and in the screw holes?I'm concerned that it could channel water inside.
Get a friend To help (I have done it by my self. ). Mark the hood hinge. Not the one with spring . Then remove bolts From the one with no spring .(friend holds hood ) Once bolt r out
u Can let hood rotate (Spring hinges still up ) Down to core support . The cowl will come right up then For allot more room. (Antenna is only thing holding it now. |
X2 on the hood. I tried it without removing/moving hood and I scratched the crap out of the cowl panel.
Got it!Thanks for the help!:-drink
So is the antenna attached to the cowl panel? And it comes out with it??
