1988 F-250 Stock 460 Engine Specs?
I recently aquired a 1988 F-250 with a 460. The engine is using a lot of oil and is very tired. I'm going to do a rebuild with some minor modifications. I'd like to know what the stock cam shaft specs are for this model year. Actually I'd like to know all the enging specs. So if there is anybody out there that has a link or just knows all the info let me know please!! You may view my Hot Rod 1974 F-100 at Login . The F-250 is what I'm going to use to trailer the F-100 to the drag strip and back. Thanks in advance!!
Camshaft Specifications.
Originally Posted by MrScharfenberger
(Post 6222584)
Lobe lift: Intake-.252 Exhaust-.278 End Play: .001-.006 Service Limit: .009 Camshaft Journal to Bearing Clearance: .001-.003 If the same as an 87 and you need any specifications e-mail me: desert1dog@earthlink.net |
