using hydrogenated WVO
I have been told not to hydrogenated that it is a real PITA to filter. I might have a line on about 300 gallons a month but it is hydrogenated oil. Can I use it? Is there a way to filter it out that wont plug my filters?
I am looking into running straight oil in a vegistroke system |
Originally Posted by luvemhot
(Post 6199021)
It works if heated
Think about a two tank system where the WVO is heated. You can find out how to use it here FRYBRID SVO/WVO FORUM an open and public discussion of Vegetable Oil as a fuel
Ken Gardner |
The Vegistroke system is a daul tank set up. You can use that oil if you like but of course you may experience a little longer switch over times. If you have bought a turn key system, then that means your entire Vegistroke system is heated.
Originally Posted by vegistroke james
(Post 6201473)
