2.3L hsc topaz 89' stumbling..
hey i know that this isnt a car faourm but hey its a ford too
the car seems to stumble when i accelerate between the 2000-3000 rpm range what would cause this problem fuel isnt the problem cuze it starts and idles well and reves well under and over the stumble thanks for the help all Jc |
Plug wires breaking down under load.
Fuel filter-flows enough at low load conditions, not enough for power. EGR valve sticking. Sparking Plugs with bad or wide gap breaking down under load. TPS sensor bad fooling the ECM into thinking you closed throttle. MAP sensor out to lunch intermittently, leaning or enrichening mix. Pull the codes, and see what you find before spending $$. The TPS can cause the trans to drop out of OD if yours has an AXOD. Again, pull the codes first. tom ps. you could get the 2.5 out of a Taurus, and have a mild sleeper... that'd be fun, lots of torque, too. |
its just my beater (drive it in the feild and backroad) so an engine swap not feesable
is there a way to check the tps for corect funtion as i checked the wires and rotor fuel plugs |
